View Full Version : What shocks to use.....
BATComm1
01-03-2008, 12:25 PM
What Shorter shock is everyone going with in the rear of the xB after you do bags ???
Gothbox
01-03-2008, 02:49 PM
5870 is what you want for th Monroe shocks.
cloin54
01-03-2008, 04:49 PM
I don't know if it's my ears playing tricks on me, but it seems like my rear setup bottoms out on the struts before the bags (bumpstops) first.. I'm using the Monroe Sensatrac 5870's. Is there another alternative that other people use in the rear to get sufficient stroke while aired out?
I'm running SS RE-6 bags with FBI brackets if that matters.
BATComm1
01-03-2008, 04:57 PM
How do you like the RE-6 bags and the FBI brackets...that what I was thinking about doing..
BurxBox
01-03-2008, 05:31 PM
I went with monroe #37243
I did an azz load of research and found these to work the best
They are shorter so at full lift they stop the baggs so the rear is almost dead even with the front
and at full drop you have about another 1" to go.
oh and I went with the SS re5's and Randode brackets
So with stock steelies and stock body kit my rear bumper is 3.75"s off the ground ( might have settled a little by now)
cloin54
01-03-2008, 10:58 PM
The RE-6's and FBI brackets work great. Lifts really high and slams low.
I will look more into the 37243's. Looks like you did do you research, from a Sienna Van with lower height compression, little lower extension, and an efficient amount of stroke. Thanks again for your help!
BATComm1
01-03-2008, 11:15 PM
Cool..thanks for all the info..it will all go into my notebook of HOPE !! LOL !
BurxBox
01-03-2008, 11:44 PM
The 37243's for the sienna van have a little different mounting hardware but can be done and in a safe and easy way.
Its just half Xb and half set up that comes with the shock.
I took some pics of what I took apart to mount them if any are interested
BATComm1
01-03-2008, 11:57 PM
I'd like to see the pics !!
cloin54
01-04-2008, 12:40 AM
yeah, I would actually like to see them too, I just ordered them from Checkers.. haha.
cloin54
01-04-2008, 04:56 AM
nm, I just got to installing them.. Same install as the 5870's but it sure went a tad bit lower. Thanks again BurxBox!
Gothbox
01-08-2008, 03:18 PM
cool, looks like I need to pick some up as well.
BurxBox
01-15-2008, 05:33 AM
So I lied I only have pics of how the stock ones come apart not what I used from them to mount Sorry guys.
But it was just trial and error on the install.
here is a pic at full height
http://i141.photobucket.com/albums/r49/burkman3333/100_1804.jpg
BurxBox
01-15-2008, 05:35 AM
and full drop
http://i141.photobucket.com/albums/r49/burkman3333/100_1800.jpg
it has settled another inch since this pic. I guess the rubber needs to stretch a little or somethin
MuNkY
01-15-2008, 11:08 PM
looks good! ill be changing my shocks out after i get everything all finished on mine! :clap:
BATComm1
01-16-2008, 01:52 AM
Can you tell me what parts you used with the shocks..or send or post pics....please
Gothbox
01-16-2008, 01:54 AM
yea I would like to know as well, what was involved to mount these.
Gothbox
01-17-2008, 02:30 AM
does it matter what year Sienna Van these are from?
Gothbox
01-17-2008, 02:58 AM
what about the KYB brand shocks for the same vehicle? anyone use them?
Gothbox
01-18-2008, 02:22 PM
well guess I will have to trial and error it. :lalala: :tap:
gta
04-10-2008, 05:25 AM
so what was needed to be modded to run sienna shocks?
Gothbox
04-10-2008, 06:30 PM
I had to absolutely nothing to them straight bolt in.
