The factory Scion under-dash lighting is way overpriced, and not very bright. So I went to Fry's to find a better solution.
Materials needed:
Cold Cathode computer case lights $14.00 each includes switch (2 or 4 depending if you want to put them under the seats)
Wire about 10' long
Butt connectors (or wires can be soldered)
Female spade connectors
Split loom
Zip ties
The install:
First go to Fry's and get some of these lights
http://www.compakintl.com/rw/light1.jpg
next, zip tie the lights under the dash. There are some brakets, and a cable to tie them to.
http://www.compakintl.com/rw/light2.jpg
next, pop off the knock out where you want your switch (you can mount it anywhere you want, but I wanted mine here)
http://www.compakintl.com/rw/light3.jpg
next, drill a hole in the knock out for the switch.
http://www.compakintl.com/rw/light4.jpg
I didnt have a large enough drillbit, so after drilling the 1/8" hole, then stepping up to 3/8", i emlarged it to the correct size with a dremel.
http://www.compakintl.com/rw/light5.jpg
next, remove the philips screw in the rear of the console, under the felt pad. Remove the console but pulling up at the front.
http://www.compakintl.com/rw/light8.jpg
next, locate the green wire that goes into the blue plug (this is not used on the cars with manual transmissions) Cut the wire close to the plug and strip the insulation. Crimp a butt connector on the green wire, and a section of wire to the other end. This is your power wire. Run the wire under the carpet to the switch. Crimp a female spade connector on the end of the wire, and attatch to the switch, You will have to remove the plastic cover below the dash, just in front of the console. There is a fastener on the right side of it, then it just pulls off.
attach a ring terminal to another wire and then secure the ring terminal to one of the bolts on the module just in front of the parking brake. This is your ground.
http://www.compakintl.com/rw/light12.jpg
Run the ground wire up to the dash like you did with the power wire.
On the lights that you tied under the dash, clip off the black and yellow wires about 4" from the black box. Do not cut off the black box! Strip the wires and attach the black wire to the ground you just ran from under the console. Attach another wire to the yellow wire coming from the light, attach the other end of that wire to the remaining terminal on the switch with another female spade connector.
Tuck the black box under the carpet under the dash.
http://www.compakintl.com/rw/light9.jpg
cover all of your wiring with split loom, and zip tie in place for a factory look.
http://www.compakintl.com/rw/light7.jpg
You can now test your work
http://www.compakintl.com/rw/light11.jpg
Put the lower dash cover and the console back in. Clean up and go enjoy a frosty beverage. You are done!
BlueBox
09-25-2003, 04:51 PM
great stuff randy...
did the button come with the cathode?
scionara
09-25-2003, 04:53 PM
Randy,
Great job on another idiot proof documentation. This is very helpful information. Keep documenting your mods then you can compile it in a book called "Modding your Scion for dummies"
eric_m
09-25-2003, 05:12 PM
excellent post, randy. i have one little suggestion. if the light shines up at you when you are driving, through the steering column, then you can put a piece of electrical tape over the top and it will only shine down, not up at you.
BlueBox
09-25-2003, 05:19 PM
hey... randy...
will the green wire work as the power supply for the A/T?
randode
09-25-2003, 09:41 PM
i may do that. actually i wont, its in kristals car so it really doesnt bother me. :D
nacy333
09-25-2003, 09:55 PM
Randy >> So I see how you are. You ditched me and decided to go and make your own FAQs to get the credit all to yourself and steal my FAQ template!!. :evil:
Anyways, great install FAQ. Next you need to somehow get a Mini-disco ball to attach to the roof with lights shining on it.
randode
09-25-2003, 10:01 PM
i'll pass on the disco ball. the next mod will be the Lambo gas cap door.
mmmmmmuuuuuwwwwwaaaaaahhhhhhaaaaaaaa.
DenZinz
09-25-2003, 10:08 PM
LMAO! Just wait till she sees your post.
BlueBox
09-26-2003, 04:52 PM
Hey Randy,
can u post pix of the second cathode rod installation...just wondernig exactly how u connected the yellow to yellow and black to black wires...
if u don't have any pix..it's coo...
avus
09-27-2003, 10:55 AM
are the cold cathode that much brighter that the LCD tubes?
BlueBox
09-28-2003, 09:32 PM
Hey Randy,
Thanx for the DIY instructions... i just installed my cold cathode rods...and they look great...
I have an A/T xB...so i was forced to split the power source (green wire)...but it works great. The whole installation took me about 1 hour... the most time consuming part was drilling the proper size hole for the switch...it looks more difficult than it is...i almost cut my finger off~
ne ways...just wanted to thank you...
next on my mod list...is to drop my car 2". I'll be contacting u for the install...thx again Randy.
randode
09-30-2003, 11:32 PM
heres the wiring diagram showing how simple it actually is
http://home.earthlink.net/~randode/diagram.jpg
SexyScionGuy
10-04-2003, 05:51 PM
Yo Randy!! Thx for the drop bro! Excellent guide! I'll be onto my light installation ASAP. =)
Yoo da man! 8)
G-Force
11-25-2003, 10:28 PM
nice FAQ - thank you for posting that!
One question: is the power source always on? or is it on only with the parking lights on? when the door opens?
randode
11-25-2003, 10:32 PM
if you tap intop the green wire, they will be on when the running lights or headlights are on. unless you switch them off. I have a plug and play version of this if you want to buy one allready done. All colors in stock.
LVXB
11-25-2003, 10:34 PM
are there any posted pics of a color besides blue in someones car?
LVXB
11-25-2003, 10:37 PM
okay i just saw the purple pics but are there any others?
randode
11-25-2003, 11:55 PM
i have green in mine, i grabbed some pics at sundays meet of some white and some blue. i will post them tomorrow.
LVXB
11-25-2003, 11:56 PM
yay!
randode
11-26-2003, 03:47 PM
im retarded. i forgot to grab my camera this morning. damnit!
Infiz
11-26-2003, 08:08 PM
Great DIY Post - I bought my coldcathodes at http://www.elwirecheap.com - they're only 11.99 for a pair of 12" Cold cathodes & they come in a variety of colors. They're in Los Angeles, so shipping was cheap, fast (they came the next day) and best of all, they didn't even charge tax!
Sid_xBicious
03-03-2004, 12:10 AM
the green wire by the blue plug, for automatic, what does it supply voltage to? is it only for shifter illumination? i already manage to hook up 2 CC in the front, will i have any problem tapping another 2 for the back? i just don't want to overload the green wire.
so, anyone with automatic did it? since when?
thanks,
sid
randode
03-03-2004, 04:01 PM
thanks,
sid
the green wire is power to the lights in the automatic shifter. You wont overload it with 4 cathodes. Cathodes hardly draw anything.
Sid_xBicious
03-03-2004, 04:05 PM
thanks randode!
i guess i'll do another trip to fry's :D
can't get enough cathode!!!
sid
DjFrOsT
03-03-2004, 04:50 PM
is this the set you ordered?
another question...where did you connect them to? how did you do it? (i'm no electric-guy or anything) do you have an on/off switch? or did you run them to a different power source?
03-17-2004, 04:33 PM
in the wiring diagram, what the heck are the black boxes??
randode
03-17-2004, 04:48 PM
power inverters
03-17-2004, 05:49 PM
so, there are four? i only have one :x
ikhonlord
03-18-2004, 03:07 AM
Hey randode...do you have pics of your "plug and Play" installation??? And how "plug and Play" is it really??
BoomBox757
03-20-2004, 12:21 PM
I'm running 11 :lol:
Max2k
03-20-2004, 04:01 PM
I've got 8 of them, under each side of the dash; under the front of the seat bracket; the back of the seat bracket; and under the slider track on the inside.
It's actually not very difficult to pull power directly off of the battery, which is what I did.
ahurdl01
03-20-2004, 04:10 PM
I am not familiar with cold cathode, but i know of the drawbacks and advantages fo the alternatives. My question is: do they draw a lot of current? Do they have a noise, like neon?
Munch
03-20-2004, 04:23 PM
No big current draw, no noise and no drawbacks :D . I have 10 in my car. 6 inside and 4 under the hood.
Max2k
03-20-2004, 05:23 PM
Very little power draw, completely silent.
To answer the earlier question, i've got red ones and i'll be taking pictures later.
ncscion
03-21-2004, 06:55 AM
i have the rs1 with the factory lights. can i tape into the wires that run to the switch for them? or will there be a problem running cc and led's from the same switch? not familiar with this light stuff sorry. any help would be great
unlmtdndeavor
03-23-2004, 12:31 AM
i went to fry's too and got the cathodes too. i bought the ones that were 14.99 for 2 12" ones. i think that was a bad choice, as they cracked so quickly. if you want to get your lights to be one w/o turning on your car or even the putting the key in, go through the back of the center console.
Malaclypse
03-23-2004, 02:02 AM
If you want good cheap cathodes, go to svc.com. I got 5 two tube, dual inverter kits shipped for about $45. I'll be putting them in the car soon, and I'll try to get some pics when I do. I spent the afternoon today hooking up my amp :)
showpaojoe
03-23-2004, 02:18 AM
unlmtdndeavor, the first time I did mine I got the exact same things at Fry's and one broke the next day. I think the guy at the car wash touched it. The last few times I have ordered from svc.com as well and I get them in 2-3 days. Never had a problem with them.
I just did my brothers car with 6 under dash/seats, door handles, glove box, engine, and trunk. This saturday I'm getting underbody kits for both our cars but I have never installed them so it'll take awhile.
Max2k
03-23-2004, 07:48 PM
Door handles? Sounds interesting...
unlmtdndeavor
03-24-2004, 08:24 AM
i think imma go return the ones i got. im kinda ____ed. the worst part is, i was storing one set in the compartment in the trunk. and cuz i unbolted my rear section, the heat was hitting right there, melted some of the styrofoam inside...and melted the box...there goes 15 dollars
Passions
04-05-2004, 09:16 PM
which wire do you connect it to if you only want them to come on when a door is opened? :?:
scionxbny
04-22-2004, 01:52 AM
Just buy Randy's kit. It's a lot easier. Took me three hours but I'm slow and very careful and double check everything and I stopped for sodas. 8)
iglcrair
06-29-2004, 05:55 AM
Hate to beat a dead topic like this, but I was reading this over and ordered a couple sets of CCFL... and ill be installing them shortly. However, i have spoken with some friends and I have been informed that many cops dont like interior lighting of the magnitude that cold cathode seems to achieve... Can anyone verify that either cops frequently pull you over with them lit or not? Or are you simply turning them on for show and not while driving?
randode
06-29-2004, 04:19 PM
i've never been stopped for it. if you do get stopped, tell them it came that way.
