Yokohama TRZ size for XA
Old Jan 5, 2008 | 03:30 AM
Bobba's Avatar
Default Yokohama TRZ size for XA
After a lot of research I have decided on a set of TRZ's for the XA. Any benefit to going with a 190/60/15 versus the stock 185/60/15 size? I am looking to improve ride and reduce noise as much as possible. Any photos of XA's with 190/60/15's would really be appreciated!
Old Jan 5, 2008 | 06:05 PM
burstaneurysm's Avatar
There's really no benefit to going wider on a narrower tire.
Old Jan 5, 2008 | 06:06 PM
Sasnuke's Avatar
I'm going to go out on a limb and say you probably mean a 195/60 15. Noise reduction is greatly built into the tire, but also operator responsibilty when put onto the car (i.e proper inflation, alignment, etc.). So a lot of road noise is dependant on you. As for improved ride, the 195 is wider giving a bigger contact patch for better grip & the sidewall is taller (60% of 195) so the ride should be smoother due to more flexing in the sidewall. But ride quality is in the hands of the steering wheel holder, only you can decide for yourself.
Old Jan 6, 2008 | 04:43 PM
Bobba's Avatar
Have any XA/XB owners replaced the stock 185/60/15's with 195/60/15's? If so, what was your impression of ride difference or handling changes? I have to decide by next weekend so others personal experience would really be appreciated.
Thanks
Bob
Old Jan 24, 2008 | 02:52 AM
powhound84's Avatar
just switched myself. it is SLIGHTLY more cushy of a ride but other than that feels the same. the grip is better, but probably because those potenzas we get are s***
Old Jan 24, 2008 | 07:28 PM
DiscountTireDirect's Avatar
If you haven't already made a purchase I would suggest the looking into a michelin. The TRZ is a great hwy tire that will last you a long time but in order to last such a long time the tire uses a harder rubber compound. For better comfort and Noise reduction look at the Michelin MXV4 Plus in the same size. They are a little softer, but are still a great hwy tire, they will be very comfortable as well.
rain7905643
Mar 14, 2015 12:48 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
