Wiring Harness problem
Old Jan 5, 2008 | 06:21 PM
sho0b0x's Avatar
Default Wiring Harness problem
In the middle of installing my AVIC D3X, and I finish routing the wiring, and taping everything up. I go to hook the battery terminal up, and turn the power over to ACC.
No life in my new headunit. So I am like damn, so i pull it part and with making sure the connections are fully seated, then from there i started touching the ends of the wiring harness with my tester. the only spot i could get to light up was the ACC.
Some reason I dont have a live battery wire, can anyone give me some insight?
I bought the wiring harness needed to hook this up, but I assumed everything would be correct, and it fit great.
Old Jan 5, 2008 | 07:48 PM
sho0b0x's Avatar
ok, well the fuse was blown for the radio, so that explains why I had no live wire.
Now I inline spliced my bluetooth box to the headunit's 12v battery feed. I am wondering if that is too much for that little 15amp fuse for the radio?
Old Jan 5, 2008 | 09:55 PM
hotboxn's Avatar
Team Echo
it shouldnt be too much, are you pos. you didnt ground out the 12v some how accidently?
Old Jan 6, 2008 | 01:59 AM
sho0b0x's Avatar
couldn't tell you honestly if that happened. I ended up cutting the wire and i put a new connector on after I put a new fuse in. Since then it has been running fine.
Old Jan 6, 2008 | 02:18 PM
Whispaz's Avatar
good to hear that everythings fine. on your D3, is there a small space just above the HU that the dash panel doesnt cover?
thats the only thing i dont like about mine but good thing its not too noticable
Old Jan 6, 2008 | 10:53 PM
sho0b0x's Avatar
yeah, that shim didnt fit, so today my father and iwas doing some mods to the car. I replaced the floor in the back cargo area with a solid sheet of box plywood, and mounted the amp under it.
I also cut a peice out and painted it grey to go around the HU. I soon as I upload the pics i will share
Now to figure out why my amp isnt pushing enough juice to my sub, and for eD to send me my box i ordered!
skruff
May 6, 2015 08:32 PM
clickclickw00t
Feb 18, 2015 08:57 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Scion_707
Dec 31, 2014 03:28 AM
oj411
Dec 15, 2003 11:57 PM
