Fuel Rail spraying out of cylinder 1
Old Jan 6, 2008 | 01:30 AM
turbotc06's Avatar
Default Fuel Rail spraying out of cylinder 1
Ok so we finally get the car back together and go to start it ....it ran for about a minute and then quickly died .... its spraying out of the topside of the injector (where it plugs into the fuel rail)
the only thing i can think of is a bad injector, the plastic ends are on the one side of the injectors and the O rings are fine on the top by the fuel rail
any ideas? please let me know asap...or instant message me on AIM!
njsciontc
im really trying to get her done tomorrow morning
Old Jan 6, 2008 | 01:42 AM
Whocares05050's Avatar
bad o ring. replace it.
Old Jan 6, 2008 | 01:55 AM
yeldak's Avatar
x2 I went through this when I installed my turbo, everything went smooth except for the injectors.
Old Jan 6, 2008 | 03:39 AM
recliner15's Avatar
o-ring was the first thing that popped into my head. For my turbo I bought a new set of stock o-rings and used those. no problems .
Old Jan 6, 2008 | 08:24 AM
BuddhasTC's Avatar
the O ring might look good but squeeze it on the sides...you might have too much play and have to replace it...had the same problem after the s/c install
Old Jan 6, 2008 | 12:50 PM
turbotc06's Avatar
thanks guys .... can i just get O rings from like a autoparts store or you suggest going to a stealership and buying them?
Old Jan 6, 2008 | 01:14 PM
yeldak's Avatar
dealership....
Old Jan 6, 2008 | 01:15 PM
recliner15's Avatar
dealership
Old Jan 6, 2008 | 03:02 PM
kikcaffine's Avatar
Dealership, they are like 35 cents there
Old Jan 6, 2008 | 03:07 PM
turbotc06's Avatar
yea but they will take 5 years to order and im trying to get it done now lol
and yes its a O ring on cylinder 1 sweettttttttt haha dont do injectors in the dark it was pinched a little between the rail and the injector
Old Jan 6, 2008 | 03:09 PM
recliner15's Avatar
so its fixed now?
anyways there a few dollars each and if you have a decent size toyota dealership around you they should have em in stock
Old Jan 6, 2008 | 03:49 PM
yamaha16bw's Avatar
Anytime ive ordered anything from the dealer it only take one day to get it in mostly.
Old Jan 6, 2008 | 04:52 PM
turbotc06's Avatar
alright fuel rail is good to go
we still are having an issue.... when we start it up she idles to like 3 grand and quickly dies out
not sure what it could be any ideas?
were stumped
Old Jan 6, 2008 | 05:25 PM
recliner15's Avatar
If it starts and dies right out.. not sure. Check all of your pipes.. espicially the intake pipe.
The exact same thing happens if you take out the MAF and start the car.. so im trying to relate it to that
Old Jan 6, 2008 | 05:55 PM
turbotc06's Avatar
she runs but sounds like a law mower ....not sure whats wrong and idles at about 2500
let me hear some ideas im done for today got work now
Old Jan 6, 2008 | 05:56 PM
recliner15's Avatar
Where is the sound coming from? We're going to need as many details as possible in order to diagnose the problem
Old Jan 6, 2008 | 07:15 PM
rodlandscion's Avatar
exhaust leak, Injectors still need reseating, leaking injector (that was mine), vacuum leak. I would check these first and all your intercooler piping. and your engine management.
Old Jan 6, 2008 | 09:06 PM
yeldak's Avatar
definetely a vacuum leak, there is a line that goes on the back of the engine, onto the intake, or fuel rail, I can't remember which one, check that....
Old Jan 7, 2008 | 02:13 AM
turbotc06's Avatar
lol if i could find out where the sound was coming from i would have fixed it silly people lol
on a serious side though ..... we redid the fuel rail like 3 times and still runs the same so definately not that
i dont know how the car would run if the timing was off a little bit ...if i did i would know if it was my timing or not
but it pretty much holds out at 2500 rpms and dumps a ton of fuel into the motor to keep her running
the only thing im thinking is the timing is off on the cylinders but if that were the case wouldnt the motor have died today and not start again because it would have bent all the valves and everything?
and also if you put your face near the exhaust manifold you can feel air blowing out of it....
im thinking my turbo could be siezed but im not looking to pull the whole thing apart so is there anyway to easily check that?
Old Jan 7, 2008 | 03:04 AM
turbotc06's Avatar
Im thinking my timing is 180 degrees out ...so if its 180 degrees out .... would that mess up the timing but not screw everything up? cause i dont remember how many times i turned the crank
