Thoughts on Custom t/c kit from the big guys
Old Jan 6, 2008 | 03:26 PM
jjos1's Avatar
Default Thoughts on Custom t/c kit from the big guys
So my s/c blew on me and was damaged upon removal of the speed rated bearings so now I am going to build a custom turbo kit. This is what I was going to start with:
Megan Racing Manifold / Down pipe ( I am pretty much set on these 2 due to the price)
A garrett t3 to4e 50 trim .63 a/r 4 bolt discharged (to match the down pipe)
Tial 38mm external wastegate.
I have the trd injectors from the s/c and oil feed and return line which I will try to use again. How much boost could I run on the stock n/a ecu with the bigger injectors ? (selling the trd fashes ecu)
I will eventualy add a aem fc/i and meth injection, I just cant afford it since I wasn't able to sell my s/c.
Old Jan 6, 2008 | 04:02 PM
Bryan06tC's Avatar
The problem with the N/A ecu is that it cant handle those bigger injectors! so you probably need to wait until you have some kind of management because your going to have to pull fuel with those bigger injectors for ordinary driving until you hit boost, then you would need to add fuel. The stock ecu would try to maintain stoich. and lose its mind with the fuel trims..
Old Jan 6, 2008 | 09:11 PM
05-RS1's Avatar
sorry to get off topic, but how'd you blow your s/c?
Old Jan 6, 2008 | 09:25 PM
jjos1's Avatar
The speed rated bearings went, the speed rated ones that hold the impeller. I will do a full write up with pics when I get enough time.
Old Jan 7, 2008 | 09:20 PM
Kumitsu's Avatar
I like the turbo that you are choosing, most SRT-4 owners choose that same spec turbo over GT30, or a 60-1. I wouldnt change it at all.
Old Jan 8, 2008 | 12:58 AM
jjos1's Avatar
So how would a 57 trim t3/t4 .63 ar spool up with a megan manifold ? how much more lag would there be compared to a 50 trim ?
Old Jan 8, 2008 | 01:03 AM
java09's Avatar
i have a t3/t04 e 57trim .63 ar with my turbo toyotas kit and considering the megan manifold is "almost equal lenght" im gonna say that it spools similar to mine. my turbo has a slight lag when i slam the pedal but once i hit about 3400 rpms then it spools super quick and loud!
Old Jan 8, 2008 | 01:09 AM
jjos1's Avatar
How many psi are you boosting ? 3400 rpm I wonder how the trd flashed ecu would work with it ? the s/c would start to boost around 3k and it would begin to add fuel.
Old Jan 8, 2008 | 01:12 AM
java09's Avatar
im running 8 psi. and am probably around 320-340 whp. final dyno will be coming up soon. but yeah im not sure how that would work, but seems like the principle is there. im sure it wouldnt run well though. my thoughts are engine management and new injectors. btw im running 550cc injectors.
Old Jan 8, 2008 | 01:18 AM
jjos1's Avatar
Yeah I figured it would be easier to start from.
I'm only going to run around 5-6 psi for now until I put together a good meth injection setup.
Old Jan 8, 2008 | 01:32 AM
java09's Avatar
well that meth injection is good if you plan on running higher psi because doesnt that just raise the octane to around 103? kinda like race fuel? i could be wrong though. is it because you plan on running only 5-6 psi NON-intercooled?
Old Jan 8, 2008 | 01:53 AM
jjos1's Avatar
I was thinking just to be safe, for raising the octane it depends on the mix you run.
Old Jan 8, 2008 | 01:55 AM
java09's Avatar
thats true too. better safe than sorry i guess.
Old Jan 8, 2008 | 04:57 AM
Bryan06tC's Avatar
I have the Megan manifold and I have the 57trim .63A/R , I'll try to get a lil data for ya in the next few days!!
Old Jan 8, 2008 | 06:50 AM
aen's Avatar
aen
60-1 turbo spools just fine with my log style manifold haha
tho at higher boost levels, 13+ it does spool a LITTLE slower
Old Jan 8, 2008 | 11:40 AM
jjos1's Avatar
Yeah I'll probably stick with a 50 trim I want get a little more low end power than the s/c was. Hey Bryan06tc do you have any pics ? sorry didn't pm you back I've been busy parting out my s/c stuff.
Old Jan 8, 2008 | 04:06 PM
jjos1's Avatar
Does anyone have a base map for a setup similiar to this for a aem fc/i ? for 5-6 psi ?
Old Jan 8, 2008 | 04:12 PM
Bryan06tC's Avatar
Hey check out Mr. Meaty he may be able to talk with you about base maps..... I will get pics up when I can, my camera is 8megapixel its actually to big to upload sometimes but I'll get pics to ya!
Old Jan 8, 2008 | 04:43 PM
Mr_Meaty's Avatar
HI!
my turbo is a 54trim, .63ar and the spool is fine...right around 3200 on my EL mani.
I think with the SC injectors (what are they, like 380cc or 420cc?) you should be OK with no manageemnt on low boost, like 5psi.
And yeah, we got maps comming out the a$$ for the f/ic! you will have to do some adjustments, but it's pretty easy to add/pull fuel.
Old Jan 8, 2008 | 05:56 PM
aen's Avatar
aen
i have a basemap.
CONCRETETC
Feb 9, 2015 08:05 PM
cid_mcdp
Jan 5, 2015 02:45 PM
DjFrOsT
Dec 13, 2003 04:18 AM
scioninla
14
Oct 18, 2003 03:46 AM
smilygo
Oct 1, 2003 07:03 AM
