Maintenance Light flashes when car first starts..
Old Jan 8, 2008 | 01:16 PM
Stooks's Avatar
Default Maintenance Light flashes when car first starts..
Anyone have this problem? My maintenance light will flash about 4-5 times right when I first start my car then it stops flashing?
hmmmmmmmm
______
Old Jan 8, 2008 | 01:19 PM
bBlover's Avatar
Uhh, all cars do it. Its normal.
Old Jan 8, 2008 | 01:35 PM
STLBOX's Avatar
It is time for an oil change. My 06 will do that, eventually the light will stay on. It will need to be reset. I beleive this info is in the owners manual.
Later
Old Jan 8, 2008 | 01:36 PM
dannygenio's Avatar
don;t worry dude...it's a warning that your car will explode...............
jk... yea time for oil change
Old Jan 8, 2008 | 01:37 PM
Stooks's Avatar
i know it usually flashes once car is started once, but this goes for 4-5 times after all the lights shut off.
Oil Change? Hmmmmm I'm not up for an oil change yet I'll have to take a look ...and I looked in the owners manual (LOL) first place i checked it said take to get serviced, i was just wondering if anyone knew off hand or had any suggestions
thanks!
Old Jan 8, 2008 | 01:40 PM
STLBOX's Avatar
If it wasn't reset on your last oil change it will need to be done (reset). Most places will not reset this if you are having your oil changed by someone.
John
Old Jan 8, 2008 | 01:44 PM
bBlover's Avatar
Maybe you need an oil change or you're close to needing one.
Old Jan 8, 2008 | 01:46 PM
dannygenio's Avatar
Are you almost hitting 5,000miles on your xB?
_____
Old Jan 8, 2008 | 01:47 PM
STLBOX's Avatar
Maybe not. See above posts. It will NOT reset itself after an oil change.
Old Jan 8, 2008 | 04:17 PM
TorchedPerfection86's Avatar
Lehigh Valley Scions
It means you either need an oil change or the last time you got one it wasnt reset. It is normal my 06.5 did this already and i called the dealership right away and it turned out that the last time i had my oil changed it wasnt reset. It's perfectly normal nothing to worry about. If your not due for an oil change then just reset it.
Old Jan 8, 2008 | 04:18 PM
You are correct it doesnt reset itself the tech must do that himself.
Old Jan 8, 2008 | 05:46 PM
SLIM187's Avatar
Like everybody is saying. Either you are due for a Service or whoever did your last Oil Change didn't reset it. If you want to Reset your Light.
Here's how you do it: Hold the Trip/Clock Button Down, Turn the Key On. The Maintenance Light will either come On and stay on, then go Off or will Flash several times, then go Off.
Once it goes Off, Turn the key Off and then Release the Button. Then Start the car up and it will go Off. Try that.
__________
Old Jan 9, 2008 | 01:55 AM
TheShortBus's Avatar
i have NEVER had a Scion/Toyota service tech reset the timer while at the dealer for scheduled oil changes. i always have to do it myself after the fact--good thing it's so easy to do : )
Old Jan 9, 2008 | 04:11 AM
Sciond's Avatar
lmao...does anyone read the manual?
search is your friend...this has been answered many many times
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
BV19869
Dec 11, 2014 06:05 PM
bruceb25
Nov 23, 2014 04:52 AM
DibujoB
24
Jun 28, 2004 04:23 AM
deathcabforme
15
Oct 19, 2003 03:18 AM
