View Full Version : Swapping Single CD for 6 CD
Submerge
11-07-2004, 03:02 AM
Greetings,
How difficult is it to swap a 6CD for a singe CD radio in an XB? My new xB came with a singe and my wife does not use the 6 CD changer in the xA.
Thanks,
Dave
BoomBox757
11-07-2004, 03:28 AM
pop the center dash off, unscrew the cd player, un hook it. do the same to the other car then, plug it in, screw it in, and put the dash back on., should take no more that 30 min
BabelBox
11-07-2004, 03:34 AM
It's very easy. I can't find the exact topic to replace the head unit. But you can check this postt.
http://www.scionlife.com/forums/viewtopic.php?t=23214
RogueXB
11-07-2004, 04:33 AM
Don't you need a security code to reset them??
Thats whay I heard.
BabelBox
11-07-2004, 01:49 PM
No security code. I bought my 6-disc head unit from another member here. It was a brand. It's easy as Plug and Play.
Submerge
11-07-2004, 04:44 PM
Would appreciate a few more details on how to get the center dash off. Last thing I want to hear when pulling is SNAP! and then see small plastic parts flying around the interior!
Thanks,
Dave
BoomBox757
11-07-2004, 06:07 PM
Thanks,
Dave
pull the ac knobs off and there are 2 screws, one behind the right and one behind the left, unscrew them and then push down on the top(right above the cd player) and pull out at the same time. its a little nerve reacking, just push down and pull. and if it doesn't come off your now pulling hard enough
rad401k
11-09-2004, 09:03 PM
if you run into what i did getting the center piece back on is the tricky part for some reason
BoomBox757
11-09-2004, 10:09 PM
put the bottom on first and walk your way up, or start at the top and work your way down, should be s sinch
Max2k
11-09-2004, 11:31 PM
It's easy to take the dash off the xB, it only takes me about a minute now that I'm used to it.
Just pull the knobs off, undo the 2 screws, grasp the console firmly by the A/C ducts, and pull straight out. You'll get about 2 inches of play before you have to unplug the 3 wire harnesses.
BoomBox757
11-10-2004, 01:11 AM
ohh yea once its popped off stop pulling and undo the harnesses
oops if you kept pulling that wouldn't be good at all
