Bad Coil Packs?
Old Jan 9, 2008 | 09:11 PM
Reckless180's Avatar
Default Bad Coil Packs?
What going on guys. Im fairly new to the Scion Tc's and need a little help. I have an 05 Tc with a Greddy Turbo . I recently replaced the Greddy plugs that I had with some AutoLite "XP's" and everything was going great until my car started breaking up under throttle and sometimes it stalls. I got a check engine light and checked it with a scan tool and its reading a coil pack malfunction with all cylinders.
Now my question is could this be because of the plugs? And reason why im asking is because a friend said it may be a problem with the emanage. Has anyone come across this problem before? I just wanted to check on the boards before I spent $100.00+ on new coil packs. Any help is much appreciated.
Old Jan 9, 2008 | 09:16 PM
kikcaffine's Avatar
Put the old plugs back in, reset ecu and see if problem comes back. Ps if your changing plugs put in the IK24's. I think they are made by denso.
Old Jan 9, 2008 | 11:21 PM
OuterHeaven's Avatar
Also make sure the gap is correct.
Old Jan 10, 2008 | 02:37 PM
Yesterday I replaced the sparkplugs w/ Denso IK22's. Stock heat range is 20, so the 22's are one step colder. They come pre-gapped at .028, so I figure that's fine for boost. I reset the ecu and went for a test run. Normal driving was fine, but as soon as I stepped into boost, the engine started breaking up and stalled. I pulled off the road and the engine code was the same as before...all 4 coils
Funny thing is that the entire set up has been fine for thousands of miles. It only started screwing up when some jerk used autolite sparkplugs
Old Jan 11, 2008 | 02:32 PM
brett561tc's Avatar
i've been having trouble blowing coil packs in my car as well. dont know why though?
Old Jan 11, 2008 | 02:43 PM
SePaTc's Avatar
i'd check to make sure all the plugs are tightened down first.
but otherwise, i'd say it seems pretty obvious. If it was fine before u changed plugs, then u changed plugs and its F'd up.....then its probably the plugs.
Old Jan 11, 2008 | 03:01 PM
cabrera1985's Avatar
Does your car sound like an WRX sound? When you stepped the Gas does it seem that its doesnt have any horsepower? IF so then it is the Emanage. Thats what happen to me so i had to get a new Emanage.
Old Jan 11, 2008 | 03:09 PM
SePaTc's Avatar
omg.... the noobness is killing me! :D
don't even know where to start.
Old Jan 11, 2008 | 08:29 PM
Nope. The car sounds exactly like it should. There are no errors in the emanage. I forgot to mention that it was tuned on the wastegate set boost levels. AFR is ~11.0-11.5 at full throttle.
Old Jan 12, 2008 | 04:58 AM
kikcaffine's Avatar
Maybe bad gas?
brett561tc
Sep 15, 2015 06:33 AM
sethmskinner
Aug 4, 2015 02:38 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
stenger
Jul 15, 2015 01:03 AM
goatbelly
Jul 12, 2015 10:13 AM
