S/C Pulley Bolt Loose
Old Jan 10, 2008 | 03:07 AM
JPsTc's Avatar
1UP Crew
Default S/C Pulley Bolt Loose
Ok so I was poking around in my hood and found that the bolt on the s/c pulley was loose. I could actually unscrew it with my fingers. I tightend it back up with my hand and havn't had any problems. Wasan't the pulley bolt suppose to be torqued to 40lbs?
Also, a friend of mine who also has the s/c is dealing with the same thing. Has anyone else dealt with this and is there really anything to worry about?
We tried to tighten the bolt but we can't because the pulley actually spins as we try and torque it. Any suggestions on how to stop the pulley from moving?
Any help is appreciated, thanks.
Old Jan 10, 2008 | 05:44 AM
adg016's Avatar
Impact gun set on a very low setting.
Old Jan 10, 2008 | 01:48 PM
Crippie's Avatar
1UP Crew
is there another way other than the IG?
Old Jan 28, 2008 | 02:09 PM
BLUEMEANIE's Avatar
Team Hamster
bump.
I'm having trouble breaking it free. Same thing is happening, the pulley keeps spinning.
Old Jan 28, 2008 | 06:55 PM
2_much_tc's Avatar
^ i believe you need some resistance hold the pulley in place.
Old Jan 28, 2008 | 08:20 PM
BlKtC05's Avatar
just take the whole drive shaft assembly apart. if you have the right wrenches and time its about a million times easier and you dont have to spin the the blower with an air tool. once you have it out put one wrench on the arp bold at the blower end of the shaft and the pulley bolt comes off no prob. and when you put it back together you can correctly torque that bolt to 40lbs.
Old Jan 30, 2008 | 11:48 PM
GammaTNT's Avatar
Take the belt off,
Then use a Strap Filter Wrench with some sandpapaer inside.
That was how i install the 9.5 pulley.
Old Jan 31, 2008 | 02:36 AM
BlKtC05's Avatar
nice wrench, where did you get that fancy piece of engineering?
Old Jan 31, 2008 | 04:48 AM
GammaTNT's Avatar
pep boys and advance auto parts sell them
it is actually 2 tool . the strap filter wrench and belt tool.
Old Jan 31, 2008 | 01:51 PM
JPsTc's Avatar
1UP Crew
Great info, thanks!
Old Jan 31, 2008 | 07:46 PM
BLUEMEANIE's Avatar
Team Hamster
I have the belt tool, I'll need to pick up the strap wrench.
Old Jan 31, 2008 | 10:37 PM
BlKtC05's Avatar
thanks man!
yhwhdesign
Jun 11, 2021 03:34 PM
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
xjleitex15
Aug 17, 2015 12:09 AM
gqdabien
Jul 30, 2015 07:04 PM
