Best bulbs for my XB with projectors.
Old Jan 10, 2008 | 01:51 PM
StarSk8er_00's Avatar
Default Best bulbs for my XB with projectors.
Ok, so here is the deal..... I drive at around 4:15 AM to work each morning and my drive is on a back road with no street lights and a lot of fog. (Sounds like a horror movie) The question I have is what would you suggest to be my best solution for lighting? I currently have installed on my car these headlights
I know these headlights do not recommend using a HID kit in them but I want to know if anyone has had any success at all with putting some in these headlights. I also want to know which non HID bulbs work best for your money when it comes to brightness.....I am currently looking at some Sylvania Silverstars just for the fact they seem to be good and I can get them today.
Any suggestions?
Old Jan 10, 2008 | 02:32 PM
dugzilla's Avatar
A lot of people run hids with those lights.
4300K is perfect IMO
Buy a kit from Cliff in sponsored sales, you can't go wrong
Old Jan 10, 2008 | 02:50 PM
burstaneurysm's Avatar
Just do HID and be done with it.
HID actually burns cooler than a regular halogen... the only reason it's not recommended is because the optics on those headlights were designed around halogen... but HIDs will work fine.
Old Jan 10, 2008 | 03:01 PM
Ok I guess my next question would be what kind should I buy since the stock XB headlights use one bulb, but these projectors use two (one for high and one for low)?
Old Jan 10, 2008 | 03:03 PM
dugzilla's Avatar
you only will use the hid in the low beams and that bulb is a 9006, but make sure you tell cliff that it's for the xb so you get the right connector.
You don't need the highbeam to be HID... leave those bulbs alone... all you need is the low beam... not sure what bulb size is though... although I'm sure someone with these can chime in... like Doug.
Old Jan 10, 2008 | 03:06 PM
The way these headlights work is that there is a splitter going from my stock connection which changes the bulb size. Would you recommend just hooking the HID kit into the splitter so that I would still have the high lights or would you just go straight into the stock connection and not use the high slot that is on the headlight? Does that make sense?
Old Jan 10, 2008 | 03:07 PM
Also could you give me a link to cliff?
Old Jan 10, 2008 | 03:33 PM
dugzilla's Avatar
the kit cliff has you will still be able to use your high beams too.
his customer service is great!
https://www.scionlife.com/forums/vie...060&highlight=
Old Jan 10, 2008 | 04:40 PM
Do you know if the kits are still $170.00?
Old Jan 10, 2008 | 04:46 PM
dugzilla's Avatar
I'm pretty sure they are, PM Cliff with any question and he will take care of you.
Old Jan 10, 2008 | 04:50 PM
Ok I did a couple of hours ago.... but just waiting on a reply.... Thanks!
Old Jan 13, 2008 | 09:46 AM
Bossman's Avatar
i know in real projector housings like from a bmw etc. they use a fitment of D2S or D2R but since these are 'aftermarket' projects im sure they only require the 9006 size, but ask if you need to glare shield still so you dont have flares or blinding beams to on coming traffic.
Old Jan 14, 2008 | 05:02 AM
daneisthegreatest's Avatar
Cliffud is a great person to do business with....I have the sonars like you and have HID's in mine, I have 8000K bulbs in the low beams and 3000K in my fogs...and soon to be 12000K in my high beams...
with fogs on
without fogs on
at eye level with the passenger
the light output is great
Old Jan 14, 2008 | 05:15 AM
Murbyrne's Avatar
MN Scions
yea, i got some HIDs from ciff too. Im just waiting for a day to install them. But from my experience he was very helpful in picking out which brightness, size, ect
Old Feb 6, 2008 | 10:21 PM
babynum2's Avatar
so what was the final verdict starsk8er? im in the same pickle right now, and i dont know what to do.
Old Feb 6, 2008 | 10:25 PM
jallamas's Avatar
Nice info!
John
Old Feb 7, 2008 | 02:20 AM
snowromance's Avatar
there is some good info and some horrible info here.
if you are going for function, get regular halogen bulbs for your projectors. the projectors in those headlights are made for the optics of a halogen bulb. NOT hid. an OEM hid setup uses a projector thats made to correctly illuminate the beams of your headlights.
you are going to have horrible results if you just slap an "hid kit" in there. i promise you. the hotspots will look like crap and you will annoy other people on the road.
Unless you are going to get some HID projectors and retrofit them in these headlights, stick with a halogen bulb. the silverstars are GREAT.
8000k? 12000k? that will have less light output than stock bulbs. many people dont understand this.
people merely do this to hopefully look cool and that is it because they are not an "upgrade" by any means. in fact, they would be a downgrade if anything.
Old Feb 7, 2008 | 10:54 PM
jallamas's Avatar
You have a PM.
Old Feb 8, 2008 | 07:43 AM
um...snowromance...were you targeting me with the whole 8000k and 12000k thing cuz i think you were...
Let me just clarify that know that 12000k light output is about the same as a blacklight, thats why its going in my highbeams (which i never use) just so its different...
the 8000K is by no means a downgrade to a halogen bulb, yeah its not complete light output but its still close to 3 times brighter than halogen
unless you know what you are talking about, dont say anything because it kind of makes you look stupid...just my .02
