View Full Version : Pics of cleared headlights, billet grills & tint
pileofmonkeycrap
11-07-2004, 07:22 PM
I figured I'd start a new thread since my last one didn't include pics. So here they are.
http://www.scionlife.com/gallery/data/500/9130Xb_new_grills_cleared_heads_front.jpg
http://www.scionlife.com/gallery/data/500/9130Xb_new_grills_new_heads2.JPG
http://www.scionlife.com/gallery/data/500/9130Xb_new_grills_heads3-med.JPG
hotbox05
11-07-2004, 07:24 PM
i think i dont like that grill but i like the tint and good job with the clears
stankubrick
11-07-2004, 07:30 PM
8) Looks nice and clean!
Got any close-up shots of the grills? Particularly the lower ones? I'm thinking of getting the lower 2 only. Which brand? How much? and where? :)
pileofmonkeycrap
11-07-2004, 08:00 PM
The grills are an official part and not aftermarket. Part # 00016-79045
I'll take some closer pics of the lower grills. I'm thinking of adding a Bb emblem on the upper grill so it's not so empty.
BLeeK
11-08-2004, 03:24 AM
clean...
JdMBboFSD
11-08-2004, 03:50 AM
cool......lookin good........good start......
jocappy
11-08-2004, 03:56 AM
Price of grille???
J_A_Trevino
11-08-2004, 04:28 AM
nice! what method did you use to clear your corners?
TheDanger
11-08-2004, 11:01 AM
heres his whole story
http://www.scionlife.com/forums/viewtopic.php?t=33577
pileofmonkeycrap
11-08-2004, 02:15 PM
Thanks Danger.
My recommendation to someone that wants to clear the headlights is to start with the "shatter" method, which is documented in detail in the "tech" section.
Like I said in that other thread Danger posted the link to, that method worked find for one of the headlights. But the other headlight became a problem when the amber lense broke too close to the securing tabs. At that point there was no way to remove the remaining amber lense because all that was left a long tabbed section that was in too tight.
At that point I used the oven method to loosen the silicone enough to pry open one end so I could poke out the tabs from underneath. Then the tabs just came out the bulb hole.
If you are hesitant to try to shatter the lenses and felt more comfortable with the oven method, then here's what you should do.
I would want to avoid having to seperate the entire housing just to remove the lense. Instead, just seperate the end of the housing where the amber lense is. Maybe just a 1/2" is fine. Enough to put the end of a pair of pliers in there to hold open the end while you work. Then use a thin screwdriver to poke out the tabs from the bottom. The amber lense will now be free, but too big to come out the bulb hole. Use clippers/tin snips to cut the amber lense. The lense is brittle and will break with a little clip. You'll have to repeat this on the pieces too large for the opening.
TheDanger
11-08-2004, 02:43 PM
yea towards the inside of the light there the plate has clips that go in...if you break must of it one good hit pops it out. Or you can do what my other friend did and use a clothes hanger to pull it out. I just cant do the oven method to scared.
pileofmonkeycrap
11-08-2004, 02:50 PM
Here's what I did for the oven method.
Preheat to 200 degrees
Placed a piece of cardboard on the rack
Placed my headlight on the cardboard and made sure no plastic was touching the metal rack.
Watched it like a hawk. :shock: Mainly to make sure the cardboard didn't catch fire.
I removed the headlight after 2-3 minutes just to see how warm it was and if the silicone had loosened. It didn't and wasn't very warm.
Every 5 minutes I'd remove the headlight and see if I can pry open the housing. I'd estimate it took 10 minutes of heating to be able to pry open the one end.
The headlight plastic was very warm to the touch, but not hot.
Then I used my brute strength :wink: and pried open the end.
When finished, I put the headlight back in the oven for at least 5 minutes to get the silicone loose again. Then I resealed the housing and held together tightly for a few minutes while the silicone cooled and hardened again.
theappe
11-08-2004, 03:02 PM
nice car man.
here is my box and tints1
http://img.photobucket.com/albums/v502/theappe/Scionside.jpg
pileofmonkeycrap
11-08-2004, 04:33 PM
Nice! The tint and wheels look awesome together.
J_A_Trevino
11-08-2004, 07:40 PM
so can we all post a pic of our car in this thread?
pileofmonkeycrap
11-08-2004, 10:31 PM
Sure, why not? :D
J_A_Trevino
11-08-2004, 11:10 PM
i cleared my headlights about 45 min ago using the screwdriver method, i'll try to post some pics tomorrow or the next day but for now here is one of my xb. :D :D http://img.photobucket.com/albums/v474/_666_jesus_999_/rims/002_02.jpg
OB936
11-09-2004, 07:37 AM
I like your wheels!! what are those?
Thanks
J_A_Trevino
11-09-2004, 05:34 PM
Thanks
tenzo r mean 6's in ultra black with the maxi lip, thanks :)
UnFocused
11-09-2004, 06:50 PM
Nice Wheels guys- what sizes do you have?
J_A_Trevino
11-10-2004, 04:15 AM
18 x 7.5 42mm offset with 215/35 18 kuhmo's
Curious_George_238
11-10-2004, 03:53 PM
My dealer ran that part number and nothing came up. Is there more to it?
pileofmonkeycrap
11-10-2004, 05:31 PM
Does you dealer offer a billet grill set? That part # was off of the installation instructions and was the only identifying info I saw. I'll check again tonight though.
TheDanger
11-10-2004, 05:52 PM
yea the dealer I go to has a lot of xBs with them.
Curious_George_238
11-12-2004, 03:59 AM
Another question. How does this grille set compare to the fit and finish of the one that comes stock on the Hot Lava? Also too, what type of price are we looking at?
