Suggestions? Squeaking when starting up and accelerating...
Hey, I just purchased a 2005 Scion XB and i love it. The problem is, in the last few days its gotten a lot colder. And now upon startup and accelerating from a stop, I hear this chirping / squeaking sound coming from the engine area. The chirping speeds up as the rpms get higher in first and second gear.
But I also noticed the squeaking stops after like 10mins of driving, once the car has heated up. Which could be kind of annoying, since if I take it to the shop by the time I get there the sound will probably be gone.
Any ideas of what it could be? Or if you have had a similar occurence?
Thanks in advance for any help.
pre-owned is pretty much BS, just a great way to charge more for a used car.
160 point inspection is pretty much, does the car start, does it make any funny noises, do all the running lights work, do all the buttons do what they are supposed to, do the doors open and close, do the windows go up and down, are the tires round, do the brakes stop the car etc.
you could figure all that out test driving a used car yourself. so yeah, your belt could need replacing or dressing or whatever.
Definitely the belt, I would return to dealer and politely ask them to replace the belts.
As someone who does the occasional Toyota pre-owned certification, I can tell you that the checklist of thing to check & service is as long as my arm. If the Tech does his job properly, the car should be prepared for sale better that the average used car.
Then again, we are all human & make mistakes, the belt was probably missed.
The dealer should have no hesitation in correcting it for you.
Originally Posted by sam_shizzel
... purchased a 2005 Scion XB... upon startup and accelerating from a stop, I hear this chirping / squeaking sound coming from the engine area. The chirping speeds up as the rpms get higher in first and second gear... the squeaking stops after like 10mins of driving...
I haven't looked to see if our xA's have a tensioner on them, but I would guess that they do. That is usually the cause of a "chirping" sound in regards to belts. Usually a slipping belt is more of a "squealing" sound.
Originally Posted by LeroyJMC
... Usually a slipping belt is more of a "squealing" sound.
He's evactly right, there is no tensioner besides a long steel bar wedged against the power steering pump. I have a lot of squeaking now that it's colder as well, but it's coming from the supercharger belt and not the serpentine. Just one of the "features" of the charger and can't really be gotten rid of through tightening or belt dressing, might end up replacing the belt later if I can find a cheaper generic sub for the one Greddy sent to run from the alternator pulley to the blower.
Why did Toyota not put a brace point to pry against on the power steering pump?
mw1957
Mar 16, 2015 06:00 PM
cid_mcdp
Jan 5, 2015 02:45 PM
minter66
Dec 15, 2014 01:45 PM
2002cbr600f4i
12
Oct 11, 2004 11:38 PM
