mgmlot93
11-07-2004, 09:59 PM
Others have posted that they have problems with their leg hitting the OD button while driving. I had this same problem and I couldn't find a decent replacement shifter for less than $100. Even when I decided to go ahead and pay the $100 I couldn't find anyone who had it. So I finally got tired of it and took the center console/shifter apart. Once you get everything taken apart there is no way to shorten it that I could find - the piece you would have to shorten is metal and it is attached to the whole mechanism. On top of all that, it is threaded for the shifter to attach to it and that means you would have to shorten it from the bottom to leave the holes in place to attach to. So, after almost giving up it dawned on me - you can just flip the whole top assembly around so that your shifter release button and OD button face the passenger side. You have to cut the OD wire and reattach it after you spin it but it is fairly simple.
1) Remove center console and pop off the PRND cover
2) Cut the OD wires coming from the top of shifter about 1" from sleeve
3) Remove screws in shifter and pull the entire shifter off the post
4) Pop the top of the shifter off of the piece where the screws go in
5) Flip the shifter top around and put it back on the piece with the holes
6) Slide it back on the post and splice the OD wires back together
7) Reassemble everything in reverse order and put console back on
Works great now - and no hitting the button all the time!! Plus - cost = $0.00
