View Full Version : I have some questions - need answer fast!! HELP!
CSOCSO
01-13-2008, 02:56 AM
hi all.. sunday morning i will go to buy some audio stuff for my car... but i dont know if i could buy some mid range speakers and replace the front and the rear without any worries/ problems? :
do i need some special plug / connector or just cut and solder?
about the front: the factory speakers are components right? can i change only the mid range speaker and keep the tweaters or i have to buy the component set and change everything?
there is any write up how to take apart the doors and rear panels?
let say the sub is 250 rms then i have to look for an amp wich has the same rms power or more /less??
and 2 or 4 ohm??? i will go with a single sub with a dual channel bridged amp
pls answer asap.. at the morning im leaving the house
CSOCSO
01-13-2008, 03:06 AM
i was thinkin to get the factory sub ( which goes to the side right above the wheel) and change the 10" sub for something else.. is that possible?
boostedbox06
01-13-2008, 03:09 AM
if you replace your speakers you should get e decent 4 channel amp to get the most out of them....the stock wiring and HU won't power them to their full potential...
O5_TRD_tC
01-13-2008, 03:16 AM
a lot of people have swapped out the oem sub
CSOCSO
01-13-2008, 03:24 AM
by swapping the oem sub i mean : keep the custom fit enclosure and put another 10 inch sub in it..............
CSOCSO
01-13-2008, 04:24 AM
no more replies?
O5_TRD_tC
01-13-2008, 04:46 AM
search, i knew what u meant by swapping out the sub.
