UB LED question
Old Jan 14, 2008 | 12:27 AM
Glowbox's Avatar
Default UB LED question
I recently had an LED UB kit profesionally installed and will only turn on with key in the ignition and in on position so the wireless remote is kind of pointless. is there any way i can make it so it the lights will turn on without the key in the ignition?
Old Jan 14, 2008 | 12:30 AM
SquallLHeart's Avatar
yes.
you'd need to rewire it to a power source that's live even without the key in the ignition.
Old Jan 14, 2008 | 12:40 AM
Glowbox's Avatar
Do you know where the wire would be right now being hooked up to the ignition?
Old Jan 14, 2008 | 12:58 AM
swartzautoman's Avatar
just wire it to the battery with a fuse and a rocker switch, its too easy
Old Jan 14, 2008 | 01:05 AM
no. you'd have to have a little chat with your "professional"... or you can take a look at the wiring yourelf and trace it back.
Old Jan 14, 2008 | 05:27 AM
D_M_A_N's Avatar
There is a step by step DIY in the tech section
Old Jan 14, 2008 | 04:01 PM
Glowbox's Avatar
Thanks for everyones help. I found the DIY article and will try that tonight.
Old Jan 14, 2008 | 04:19 PM
Glowbox's Avatar
I re-looked at the DIY and since the LEDs already have a switch and the ground hooked up, do i just need to plug in the wire thats hooked up to the ignition to an always active fuse?
Old Jan 14, 2008 | 04:35 PM
you can just run it to the battery with a fuse
Old Jan 14, 2008 | 05:14 PM
D_M_A_N's Avatar
Yes you can do that. Look in the fuse box under the dash on the drivers side. I think in the tech it shows which ones are always on and which one only comes on with the key turned on (like the cig. lighter)
Running to the battery is a little more work than just running it to an open slot on the fuse box under the dash on the drivers side.
If I remeber correctly, in the tech, the guy just cuts a horseshoe connector in half and jabs it into the open slot on the fuse box.... dont do that, get an "add-a-circuit" from Autozone or O'rielys (or whatever auto store is around where you live )
Doing it that way is easy as pie!
Old Jan 14, 2008 | 08:21 PM
Glowbox's Avatar
So i followed the wires from the back of the controller and there are 3. one connects the bars to the controller. the other two are stuck together.
This is one is spliced into a blue wire. do I cut the black one and add a circuit to the fuse box?
The other is spliced into another appearing to be the ground.
Old Jan 14, 2008 | 08:51 PM
D_M_A_N's Avatar
If the black one is the positive wire that goes to the switch, then yes.
Be sure to tape up any bare wires after you cut it from the blue one.
Old Jan 14, 2008 | 08:53 PM
D_M_A_N's Avatar
The ground you can leave alone as it is.
Old Jan 14, 2008 | 09:00 PM
Glowbox's Avatar
Ya, it is the positive wire. I will try it either tonite or tmrw and let you know how it goes. thanks so much for the help!
Old Jan 14, 2008 | 11:27 PM
Glowbox's Avatar
One more thing. does anyone know where an always active fuse in the fuse box would be?
Old Jan 15, 2008 | 03:56 AM
D_M_A_N's Avatar
yes, I'll try and find that out for you. I'll have to go look cuz I can't remember off the top of my head.
btw, how much is "professional installation" running?
I would get some wire taps instead of just using electrical tape to splice the wiring
Old Jan 15, 2008 | 04:39 AM
D_M_A_N's Avatar
Here are some pics.
For the future, when you are taking pics of something close up like you did with the wiring, use the "macro" function on your camera. It will focus things at very close range.
Enjoy the pics:
As you can see, I added a circuit for my lighting to the "always on" slot.
Also, for the future, if your radio stops working and the lights on the radio dont come on, your cig lighter plug doesnt work, then check your ACC fuse.
Old Jan 15, 2008 | 02:43 PM
Glowbox's Avatar
Thank you so much for your time and taking it step by step with me. As you can tell I'm new to this and really appreciate your time and all your info. I got the kit for $230, 7 colors, 8 modes, and music interfacce with wireless remote. and it was $210 for installation which i think is ridiculous. lol. One last question, do i add fuses to the add a circuit for the lights? If so what type do i get?
Old Jan 15, 2008 | 03:11 PM
D_M_A_N's Avatar
No problem.
Yes you need to add a fuse to the circuit. I cant remeber what I have in mine. But the line doesnt work without a fuse.
Just use the same kind of fuse that was already in line on you current wiring setup....
wait, please tell me he did install a fuse!
I ended up with a couple of fuses in line.
I think the one in the picture facing down is a 7.5amp.
I think I would install someones for a couple hundred bucks. Its a real pain to fit under the dash and get all the wires run outside under the body.
Post up some pics when you're done.
Old Jan 15, 2008 | 03:19 PM
Glowbox's Avatar
no, he didnt install a fuse. he just used the electricity from the ignition wire. What should i use? some of the kits like the one i have has a cigarrete outlet plug so it would be 12v.
