greddy ultimate
Old Jan 14, 2008 | 04:08 PM
boosthappy's Avatar
Default greddy ultimate
does any one have any base maps for the greddy ultimate..thankz
Old Jan 14, 2008 | 04:20 PM
java09's Avatar
what size injectors you running? people need more info.. what size turbo? what this what that..
Old Jan 14, 2008 | 04:26 PM
boosthappy's Avatar
t3/to4e on 550cc injectors
Old Jan 14, 2008 | 06:49 PM
Mightygnu's Avatar
Where are you located, depending on the air pressure it will "F" with your tune if someone to just hand you a basemap.
I am running the same thing, T3/T4 E54 Trim / .63 AR
Running it on a emanage blue though..
Old Jan 14, 2008 | 09:48 PM
paul_dezod's Avatar
Scionetics
KAD
You can DL a map to tunker with here:
http://www.dezod.com/tech_notes.cfm
Old Jan 15, 2008 | 11:40 AM
boosthappy's Avatar
paul how good is that base map
Old Jan 15, 2008 | 01:38 PM
paul_dezod's Avatar
Scionetics
KAD
It's ok. It's good enough to get you started and working in the right direction. It is GReddy's tune for the tC that comes preloaded on their kits.
Old Jan 15, 2008 | 04:20 PM
boosthappy's Avatar
ok that sounds good but wat was the Correction yall did with base map like adjustments for both Fuel and Ignition..thanks
Old Jan 15, 2008 | 09:43 PM
boosthappy's Avatar
? any one
Old Jan 15, 2008 | 09:49 PM
draxcaliber's Avatar
dude, there is no universal tune for a turbo tc.
there are many many varibles to take into account that you and your tuner need to dyno and adjust to make it work for your car.
a basemap is just a starting point, a virtually 100% safe tune that is extremely conservative so that almost anybody can use it, but it won't produce very stellar whp numbers.
so start with that, put it on a dyno, and start tuning it.
Old Jan 16, 2008 | 12:14 AM
boosthappy's Avatar
thankz
Old May 19, 2008 | 09:10 PM
boosthappy's Avatar
i have been making adjustments with greddy ulti and im tryin to raise rev limiter and its still boncing off the stock limiter can some one please help
Old May 20, 2008 | 11:31 AM
boosthappy's Avatar
bump
Old May 22, 2008 | 09:59 PM
boosthappy's Avatar
have any body seen V-manage in map select in the greddy ultimate cause i have it and i thought v-manage wasnt a feature in the ultimat unless they updated it
Old May 22, 2008 | 10:00 PM
boosthappy's Avatar
tckid21
Jan 9, 2016 09:19 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
carid
Aug 31, 2015 11:17 AM
Subaru86
Jul 31, 2015 04:00 AM
