funny noise in rear passenger quarter panel?
Old Jan 16, 2008 | 10:57 PM
super-tc's Avatar
Default funny noise in rear passenger quarter panel?
I can hear some wierd clanking sound in the back of my old 05 xb in the rear passenger quarter panel. I hear it when i hit bumps and when i am on an uneven road. from inside the car it seems that it is behind the panel in between the door and the rear strut. it is soo annoying and i cant figure out what it is. has anyone else experienced this?
Old Jan 16, 2008 | 11:35 PM
Metro273's Avatar
You can push the plastic panel to the side and put your hand inside and feel around for something loose. Is there aftermarket speakers in your Box? Let us know what you find...
Old Jan 17, 2008 | 12:22 AM
tanakasan's Avatar
Maybe the exhaust clanking against something? Yeah, let us know! Never know when our box will do the same, easy fix if someones been there already. G/L!
Old Jan 17, 2008 | 12:32 AM
andrewdustin's Avatar
inside both of the rear passenger doors there are two foam (supports, sound dampning, or ssomething) pieces that are only held in by some glue and plastic rivits.
the glue may have come loose or even broken and that pieces as a result can rattle inside the door.
the samething happen to me after i hit a bump on the freeway and this was the problem that i found.
it is easy to fix... just glue the piece back on or if you have some heavy duty adhesive you could use that.
Old Jan 17, 2008 | 12:58 AM
burstaneurysm's Avatar
Could be a gerbil.
Old Jan 17, 2008 | 01:07 AM
Sciond's Avatar
My guess is there is a spring loose in its perch or a loose shock
Old Jan 17, 2008 | 04:27 PM
super-tc's Avatar
i checked under the car and the suspension looks fine. i sounds like something that is stationary on one end but flapping around on the other. Hey andrew thanks for the tip on the foam things i will check them out today at lunch. the last time i remember those foam things weren't stuck to anything so its a possibility that it could be moving around hitting something else. Man the sound is soooooo annoying.
Old Jan 17, 2008 | 04:42 PM
Sciond's Avatar
what about the rear shock tower on top?
Old Jan 17, 2008 | 04:52 PM
Driver_Lost's Avatar
No, its likely the rear quarter panel, but checking the listed suggestions would be a good idea.
Ever notice out of all the doors when closed, the passenger rear sounds the worse? Like a real twangy sound. I noticed some B's are worse than others, but all of them have it. My 4.0 is the worst in my three.
If you have a sub, or know of someone with a sub, you can see it flex and move.
It doesn't do it on the other side as much because of the gas door, and all the extra metal.
Sound insulation helps allot.
Old Jan 17, 2008 | 06:22 PM
kirksucks611's Avatar
unrelated but my dashboard rattles a lot.
in high RPM's and with Talk radio. its in 3 different places.
ones the speedometer window.. i know that for sure. and the other is somewhere above the glove box and the window.
another i think may be the panel around the door speaker.
i also have a rattle from the back passenger side but i think it was just stuff in the rear cargo compartment rattling around.
Old Jan 20, 2008 | 02:17 AM
volcom8155's Avatar
i have the same problem but i took it to my install guys and they said it is my tweeter on my speaker, so i am gonna switch that out and hope it changes. it has gotten worse so i belive thats it. good luck ill let u know what happens if it still rattles after i switch it out.
Old Jan 21, 2008 | 04:42 PM
super-tc's Avatar
is there a tweeter on the back speakers? shoot, imma check that out. i tried taking out that foam thing but it's still making the same noise. I'll keep you guys updated.
Old Jan 21, 2008 | 05:47 PM
snowromance's Avatar
keep us posted on the rattle.
Old Jan 21, 2008 | 11:23 PM
volcom8155's Avatar
well i got a piece of paper and folded it and slipped it through the cracks in the back on the tweeter on the speaker and it seemed to not rattle as bad so i am hoping mine is just that and not more. ill see if anything else comes up
Old Jan 29, 2008 | 06:54 PM
super-tc's Avatar
DUDE, you were totally right. the damn tweeter was movin. no more annoyance i fixed the tweeter. i actually need to replace it cause it came loose again. but man thanks you are the man. i super appreciate it.
Old Jan 30, 2008 | 03:21 AM
Metro273's Avatar
^^^Glad you found it! Now I need to go and check mine for rattles...
Old Jan 30, 2008 | 08:06 PM
VibrantBlue's Avatar
Aint that something. A Tweeter was the problem. That shoked me.
Old Jan 31, 2008 | 08:06 AM
volcom8155's Avatar
ya, i am mad i have to replace my speaker but o well. but i wonder if this a problem with the way the car was designed or just the odds? o well.
Old Feb 10, 2008 | 03:45 AM
L33TFooMaster's Avatar
Default Wierd Rattle
I just got my box about a week ago, and I have a wierd noise coming from the same place. Mine's an '04, and I know the sound is definately coming from the door. If I open the door and jiggle it back and forth you can hear something rattle.
I think it might be that foam mentioned before. Any suggestions about a better fix than just glueing it back in place? I don't want it to happen again once it's fixed.
Old Feb 11, 2008 | 04:20 PM
super-tc's Avatar
Default Re: Wierd Rattle
So it's the door not where the rear speaker is? I you could take apart the inner door panel and wee whats make all the commotion. Then if thats not it check your rear speakers. hopefully that helps.
