Disconnected Halos to re-install stock - Need Help!
Due to excesive fogging I decided to clear the corners on my stock headlights and re-install. When I installed the halo's I did as follows:
Pass side
Green/orange (positive) spliced in red wire from halo's
White/black - ground - spliced in black wire from halos's
Drivers
Green (positive) spliced in red wire from halos
White/black - ground -spliced in black wire from halos
I soldered the connections for each wire I spliced into. When I disconnected all I did was cut the red and black wires just before the solder and taped them back up to re-install the stockers. Now they are in, I wanted to check to make sure everything worked....nope.
My front headlight beams and front/back blinkers work and that is it. The parking lights don't work at all. Not sure what I am missing here. Anyone have an idea?
Any help before the sun goes down would be appreciated.
Thanks.
Matt
Pass side
Drivers
Thanks.
Matt
Thanks man.
I posted this up earlier today, went to double check my work....found the problem and forgot I posted this till just now. I ended up testing my lights when the pos/neg solders were touching and blew some fuse. Just wasn't being careful. All good now though. The cleared stockers don't look half bad either.
carid
Jan 8, 2015 11:33 AM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
