Wiring up map lights to come on w/ dome?
I have installed some red leds in map lights as well as the dome , has anyone wired the maps to come on with dome, was wondering if it could be done, with out losing the option to turn them on manualy, well i guess they could be wired perm to come on when u turn on dome, just jump switch from dome...any clues???
id be caeful with that.
if the 2nd gen is like the 1st gen there is a @400.00 control box to get the dome light to fade out.
others on here have put to many extra lights on that circut and fried the control box.
on a side note, that sorta sounds like a warning of experience... you blow out that box before?
uhhh.. i don't see how you can fry something like that unless someone grossly messed up their wiring... at which point, it doesn't matter what you do, you're gonna fry something.
it's very possible to wire them up how you would want to.
the box sits behind and just below the instrument cluster
only so much can be added before its overloaded.
please if you haven't done it to your car and been successful don't tell other members they will be ok.
i did not do it to my car but did find info on others that have and payed the $$
its not weather its wired right or not it has to do with the units ability.
if your so sure go hook up a bunch of leds to your dome circuit and let us know just how much it takes to fry it then you can pay the $$$$ to replace yours and we will all know what its limit is.
i have put 8 single leds on mine 2 each in the grab handles and not had problems.
I'm not willing to go more at the expense of frying that control box.
i was going to add many because of the cool fade effect and found the info just by accident.
i will try and find the thread that has the info and post a link here.
also ask Thomas (moderator) he knows
read some of these threads on the stories of failed door lock control relays. be careful in the way you go obout messing with this circut
https://www.scionlife.com/forums/sea...p?mode=results
Prolific998
Scion tC 1G ICE & Interior
04-16-2017 06:09 PM
Prolific998
07-13-2015 01:41 AM
Scorpius
10-16-2004 03:01 AM
