Pics K Sport paired with Hotchkis
Old Jan 20, 2008 | 09:04 PM
NoLimitzBuilt's Avatar
Team No Limitz
Default Pics K Sport paired with Hotchkis
Here is a pic of my rear suspension and the hotchkis rear bar. I will get in there and take some of the front. I should have done it yesterday at the show.
Old Jan 20, 2008 | 09:33 PM
al74dart's Avatar
OK, I have to ask, what are you using to adjust your springs up and down? Is there a similar device for the front also? I drive a lot of bad roads and need to get a little more clearance. The 5.1" just isn't enough. I'm going to install taller tires when mine wear out but would still like to raise my car about 1".
Al
Old Jan 20, 2008 | 10:14 PM
Team No Limitz
The K sports are adjustable coil overs. You use to spanner wrenches to adjust it.
Old Jan 20, 2008 | 10:20 PM
al74dart's Avatar
I was just on the k sport web site and did not see anything like what you have. I know what coil overs are but those don't look like coil overs at all. They look like someone took the coil over adjusting perch & lock and adapted it to work with just the springs.
Al
Old Jan 20, 2008 | 10:48 PM
coryjames's Avatar
its a shock paired with a adjustable spring perch for the rear looks like you could go alot lower nolimitz mine should be here soon you have a stagared wheel set up right? so thats probably why your not lower right????
Old Jan 20, 2008 | 10:51 PM
Team No Limitz
yeah my rear wheels will hit. They already do as it is now. I might go to a none staggered set up and run it hammered like I did my tC. I am about in the middle of the adjustment.
The site is up and running now Cory. Some of the prices need to be adjusted but it is up and running now.
Old Jan 20, 2008 | 10:53 PM
coryjames's Avatar
thats good bro im still deciding on what wheels i want i wnat to be able to tuck so i was looking at the asa jo8s and painting them
Old Jan 20, 2008 | 11:03 PM
MilfHunter's Avatar
sweet iinstall
Old Jan 21, 2008 | 12:44 AM
MikeInABox's Avatar
On cars with torsion beam rear suspensions the coilovers are usually like that. The fronts are normal style coilovers, like I think you're referring to. The rears use the separate shock and spring w/ adjuster. I know for sure that MKIV chassis VW's coilovers are like that in the rear.
Old Jan 21, 2008 | 01:04 AM
al74dart's Avatar
OK, I understand now. Any thoughts on how I can raise my xB2 about 1" all the way around without spending a fortune? I don't want to go too tall on my new tires because I don't want to change the overall gearing too much. If their was an easy way to just shim the springs that amount I think that would do it.
Al
Old Jan 22, 2008 | 01:14 PM
Team No Limitz
You can use spring spacers that they sell at like autozone. You put it between 2 of the coils and adjust it that way. I dont think they are the best thing out there, but it will work.
gcthrasher
Apr 17, 2015 10:51 AM
carid
Feb 12, 2015 11:54 AM
mark13018
Feb 6, 2015 08:57 AM
TheTripleC
Jan 4, 2015 06:46 PM
umnitza
Dec 1, 2014 06:26 PM
