View Full Version : tc- power windows not working right
aznJ
11-09-2004, 10:37 PM
I searched and couldn't find anything...but if there is already a thread about this. it would be appreciated if you'd point me in the right direction.
ok so i pulled off my door panels and replaced my speakers the other day, and when i put everything back together, I can't control my right side window at all and all the lights on the window buttons keep flashing at me! everything is hooked up like it was orginally, and i double checked to make sure i didn't short out some wire. does anyone know if you have to plug things in at a certain time like when the car is on or something? help?
its_ikon
11-09-2004, 11:45 PM
i would take off the door panel and recheck the conntections. sounds like something is plugged in the wrong place. if you already checked it then double re-check it and then triple re-check it
oneslowxa
11-10-2004, 02:04 AM
roll each window down all the way, then roll them back up all the way... use the passenger switch when doing the passenger side... you might need to do it a couple of times...
Back_In_Black_xA
11-10-2004, 04:20 AM
You have to press the passenger door window button, with it up make it go all the way down hold it for a second, than up and hold it for a second. Magically the driver door button will stop blinking and that switch will work.
You have to do this anytime you disconnect the battery in a tC.
aznJ
11-10-2004, 06:33 AM
cool... thanks guys, I went back and forth and rolled them up and down a bunch of times and that fixed it. I guess it's just setting all the parameters and stuff right? anyways... it's all good now. I never knew you had to do all that
