baggin my xb
Originally Posted by 2lowxb
doing side to side is a waste of money unless to redo the whole rear suspension, the xb's rear end won't shift side to side it will just squat down
trust he will regret just getting fb...
lines and fittings leak and thats when the independent control comes into play..
i have a bagged 98 tacoma ... and i know i would have gone crazy if i didn't have independent control of each corner.
i got a fullsize chevy with fbss, nitrogen the whole works. my box has f,b it handles fine no body roll. you don't need side to side on the back. when you hit it to the side the back will just squat unless you make the back independent
hey i wnna throw in my 2 cents, a buddy of mine has an xb that is bagged in the back only as of right now. just last night we were out cruisin and i told him to just let the air out of one bag, im not sure what you guys are saying by just squat down, but that side lowered why the other stayed high, looked as if it was performing how it should?
Having 4 valves in rear for independent control does make a diff.
It is not as noticable due to the straight axle will little articulation,but it is noticable.
The other thing about only using 2 valves in the rear is going around corners.The air from one bag will want to go to the other side when cornering.Lifting that side even more.If you cruised really slow I guess this wouldnt matter much.
When you get the front on and do side to side,the articulation will look greater.
You could use 4 valves to keep the air from rushing to the other side and not even wire switches to give you that motion.
Why is this even a question?Is it because 2 valves are cheaper than 4?
I dont get why you wouldnt set it up with 4 valves.I know a unibody is weak for side to side motion.But like I said before,just dont set it up to have that motion.
Originally Posted by Boxer0585
whats up yall.....does anybody know where i can get a F.B.S.S. air bag kit for my xb for less than $1895.00?? If not, i guess im puttin out the big bucks
i wanna build an air kit from scratch can i get some info. i will probably do 2 valves at first and if unfavorable i will go for 4. i dont wanna void my warranty tho so hmm. i guess i'll deal with that then
Originally Posted by sexyscionlover
theres nothing like putting some blood, sweat, and beers into a car
homemade is the way to go
