Light Covers
Old Jan 26, 2008 | 08:03 AM
Burnt_RS_4's Avatar
Default Light Covers
Anyone know where I can get the little covers that go over the in dash lights to change the colors of them?
Old Jan 26, 2008 | 08:10 PM
Gothbox's Avatar
Default Re: Light Covers
why just cover them when you can change them all together?
http://www.ez-bakedcustomz.com/about/leds/
Old Jan 28, 2008 | 04:10 AM
Burnt_RS_4's Avatar
Default ?
Are those plug-n-play cause I dun wanna solder anything.
Old Jan 28, 2008 | 04:12 AM
Gothbox's Avatar
Default Re: ?
yep, they replace the OEM ones, and use simple wire "t" taps so you could remove them and put it all back to stock if need be. Very EZ install with great picture directions included.
Old Jan 28, 2008 | 04:41 PM
aalbertson3's Avatar
Just get the replacment LED bulbs from Oznium. They are $2.49 and you will need two of them.
http://www.oznium.com/corvette-c5-led
Old Jan 28, 2008 | 06:44 PM
Burnt_RS_4's Avatar
Default ?
Will these work for the light behind the Speedo and the on behing the clock/odometer?
Old Jan 28, 2008 | 08:24 PM
UV7's Avatar
UV7
The LEDs behind the speedo and clock are all soldered. They are very easy to change with a little bit of soldering skill.
If you do NOT want to solder at all, you can get the kit from randode.com that covers the LEDs with a vinyl overlay, allows you to put any background that you want as your speedo background, and then has a clear acrylic overlay with the tach, speedo, and fuel gauge markings. There is an LED ring that surrounds the cluster that can be set to several different flashing and motion functions, and can be ordered in the color of your choice. It also replaces the needles with very cool CNC'd skulls.
http://randode.com/store/product47.html
This kit only affects the gauge cluster and does not alter the clock color in any way. That one, you'll just have to solder or live with it.
Old Jan 30, 2008 | 07:47 PM
Pacer's Avatar
So wait... These bulbs... where exactly do they go?
BEhiend the AC ***** and stuff?
Old Jan 30, 2008 | 09:11 PM
UV7's Avatar
UV7
http://autolumination.com/74.htm
Half-way down the page, there are Neo Wedge Based LED bulbs. These replace the existing bulbs behind the A/C controls, base and all. The factory bulbs unscrew half a turn and pop out. These pop in as a replacement, and lock in place with another half-turn clockwise.
Old Jan 31, 2008 | 06:02 PM
Yes the LEDs from Oznium go behind the HVAC. You can get all the other LEDs needed from www.garage1217.com
Old Mar 17, 2008 | 09:52 PM
biancoxb's Avatar
This is such a great tip everyone should know about, way brighter and better results than those little rubber things people use
Old Mar 19, 2008 | 07:45 AM
bB2NER's Avatar
Music City Scions
You mean "bulb condoms" Those are so 90's totally.
Old Mar 19, 2008 | 05:36 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
carid
Jan 22, 2015 12:49 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
toyotaisme
Jan 10, 2015 10:24 PM
carid
Jan 8, 2015 11:33 AM
