View Full Version : hotchkis sways question
lex990
01-26-2008, 10:57 AM
aside from getting rid of body roll... do these affect the roughness of the ride very much? or just make your car stay flatter on the road in the corners?
dex
01-26-2008, 02:08 PM
stiffening the chassis in any way is gunna make the car ride rougher. i couldnt tell you to what degree though...i didnt put them on until after i had the teins.
lex990
01-26-2008, 05:09 PM
i know it will ride a bit rougher but i wanted to know if it was a big difference or just a tad bit... i don't think they would make it as bad as drop springs
can't drop my car but alteast i could stiffin it up a bit
azureloki
01-26-2008, 05:56 PM
you mean your keeping stock suspensions except you want to add a sway bar set?
lex990
01-26-2008, 07:53 PM
yep
SoleLaced
01-26-2008, 07:56 PM
oh. I had the TRD swaybar with stock struts/springs
i actually didnt feel a difference and mine was set on race (stiffer setting).
Hotchkis are a bit thicker but Im sure you wont feel it too much, if anything
EDIT: it also depends on your tolerance.
davedavetC
01-28-2008, 12:38 AM
you will notice it big time, i have H&R coilovers, and i installed the H&R sway afterwards and it made it a little more stiff, but when you upgrade the front and the rear it will be a lot stiffer and you will notice a big improvement in handling, and if you think you cant drop your car, maybe you should look into the TRD spring/shock combo, a mild drop but increase in handling (big time), suspension upgrades are one of the most enjoyable upgrades i think makes driving the car a lot more fun. and theres nothing like taking an off ramp faster and smoother then you could stock :D
FreedomOne
01-28-2008, 12:47 AM
I'm looking forward to get TRD coil overs later this year. As for strut and sway bars, I don't own them but I believe that you would feel a difference at high speeds. That's just a guess. :question:
kungpaosamuraiii
01-28-2008, 05:38 AM
BIG difference. My friend's car on Hotchki's sways only handle better than mine on TRD springs only.
