TRD intake help
Old Jan 27, 2008 | 12:02 AM
KillerTC420's Avatar
Default TRD intake help
Ok so today I installed my TRD intake. I had no problems until I came to the lower intake pipe. The place that it has to be fastened to hold four different wires. The problem is that the existing screw will not come off. I tried everything and can't get that screw off so for the time being I have the intake held there by a plastic tie. It is pretty secure for now but I wanted to know if anyone could give me advice on how to remove that screw. I'm limited on tools unfortunately and I'm trying to avoid paying some mechanic to fix it. Anyone have any good ideas???
Old Jan 27, 2008 | 12:07 AM
curtislo9's Avatar
Pictures would help! =)
Old Jan 27, 2008 | 12:26 AM
Pictures would be hard to take because I'd have to remove the fender and the splash shield...I think the bolt is either stripped or rusted. I'm guessing stripped because I'm almost positive water can't get to that bolt
Old Jan 27, 2008 | 12:28 AM
SquallLHeart's Avatar
uhh.. are you talking about the ground wire on the inside of the fender?
well the nut side is welded on... and the bolt is a 10mm..
were you trying to remove the welded nut?
Old Jan 27, 2008 | 12:30 AM
maximthegreat's Avatar
go to a hardware store and buy a kit that removes stripped bolts, it looks like this http://www.amazon.com/IRWIN-394002-B.../dp/B0000EI9B6
craftsman makes it too
yeah thats the bolt i need to take off...i tried a ratchet and i tried various wrenchs but it wont come off and i need that to come off
Old Jan 27, 2008 | 12:31 AM
I guess my real question would be...Is it necassary to have that fastened in that last spot even if upper and middle intake pipes are fastened?
Old Jan 27, 2008 | 12:42 AM
it would be safe to do so... install it the way it was meant to...
Old Jan 27, 2008 | 12:46 AM
I guess I'll have to jack up the car and take it apart again and try my best to get that screw off...so no one has any good ideas to help me get that screw off? any kind of lubricant i can buy...special tool...anything?
Old Jan 27, 2008 | 12:50 AM
a 10mm ratchet.... if you really have issues... try some wd-40
if that doesn't work... hit the gym.
Old Jan 28, 2008 | 03:23 AM
tCeeder's Avatar
i'm guessing you were trying to take off the welded nut on the wrong side. go around to the front side and remove the 10mm bolt and just relocate the ground bolt to the frame like it tells you
airmankevin1
Feb 14, 2018 01:23 PM
Greg S
Jul 21, 2016 07:28 PM
danielv
Aug 26, 2015 07:14 PM
mark13018
Feb 6, 2015 08:57 AM
JPuehl
Jan 10, 2015 01:01 AM
