View Full Version : xB cruise control install problems! Those w/cruise Help! Pic
tcm_xB 11-11-2004, 01:36 PM Can someone tell me if I have the cruise / throttle body connection right?
http://memimage.cardomain.net/member_img_a/680066_25_full.jpg
Is the bracket suppose to be on the side with the red outline? I also think I f**ked up by loosening nut 1 and not number 2:
http://memimage.cardomain.net/member_img_a/680066_28_full.jpg
Also, can someone tell me if the throttle cable has some slack in the line? I think mine may be a little to loose now, but not sure.
The pictures in the instructions I have are so damn $hitty!!!
tcm_xB 11-11-2004, 01:51 PM How the hell do you get to the back of the fuse panel to insert the brown power wire with the 1,000,000 wires in the way????
Did you guys remove the entire fuse box so you could face the wiring toward you?
Man, I am ready to take the $hit out and sell the damn thing :evil: :evil: :evil: :evil: :evil:
tcm_xB 11-11-2004, 02:09 PM Help?!?
bump! I don't have a cruise control.
you should take a look at some of the input from the allscion.com website?
http://www.allscion.com/cruisecontrol_remarks.html
Hope this help
boilerman 11-14-2004, 04:22 PM I doubt this will help but maybe.
http://www.allscion.com/cruisecontrol_manual.html
superjeer 11-16-2004, 12:04 AM lol, I checked mine, which is a retro fit, so it's not the source of truth, but the hand made bracket :shock: on mine looks to be in the same position as yours.
Also, there's not slack, but I can deflect the cable 1/4" either way without much pressure at all.
Finally "back" of the fuse panel.?
try pushing up on the backside of the little cubby in front of the fuse block (down by the hood release).
http://www.scionlife.com/forums/viewtopic.php?t=29238 has a pic of what I'm talking about. (it's under a "TOOLS" heading.)
tcm_xB 11-27-2004, 05:35 PM Ok, I'm finally over the flu and back to this $hit!
Just snapped a picture of the fuse panel with the cubby pocket removed:
http://memimage.cardomain.net/member_img_a/680066_35_full.jpg
What I see in the picture of all the fuses / relays and whatever the hell else is there does not match up with the $hitty drawings in the instructions.
The place(s) where I tap in. Can you see them in the picture?
tcm_xb: wishes this came installed with the car :(
SmartAss 11-28-2004, 02:35 PM I can check it out on monday when I unpack.
tcm_xB 11-30-2004, 01:25 PM Over 200 views and not much help :?
xB is for sale in the classifeds if interested :idea:
superjeer 11-30-2004, 03:41 PM do you have a test light? You want a power supply that comes on with the key, but off when the key's off.
tcm_xB 11-30-2004, 05:20 PM do you have a test light? You want a power supply that comes on with the key, but off when the key's off.
I know what I need to tap into. Just don't know where it's at....
superjeer 11-30-2004, 05:50 PM so, I take it you don't have a tester?
http://store1.yimg.com/I/bradystools_1820_44657105
http://www.bradytools.com/circuittester1.html
SmartAss 11-30-2004, 07:57 PM What wire are you trying to get?
If you jsut trying to get ignition or battery go straight to the ignition harness near the key cylinder.
tcm_xB 11-30-2004, 10:51 PM What wire are you trying to get?
I'm trying to figure out the complete wiring of the cruise. The instructions tell what pins to tap into for power, but I can not find them in the car....
I do not have a test light. I have a multi-meter if that matters 8)
SmartAss 11-30-2004, 10:53 PM How about make a list of the wires you need...... post them and it will be easier to help you.
romhog 12-01-2004, 07:13 PM ok so mental note to self, just have dealership install mine when I go to pick it up.
superjeer 12-01-2004, 07:19 PM How about make a list of the wires you need...... post them and it will be easier to help you.
Yeah, if you know you need switched power or constant power or low power only on Tuesdays... let me know and I'll use MY tester, but yse, your multi meter will work. IT should tell you when you have current (and it's all 12v current).
tcm_xB 12-01-2004, 10:58 PM Ok guys.....
Here are the instructions that came with the cruise:
http://www.toyotaparts4u.com/0001679910xAxBCruise.pdf
Page 7 which is for the wiring for the cruise control. All those fuses / relays, whatever the hell they are..... I do not know where they are..... Are they in the pic above (in this thread) that shows the fuse panel?? If not, where are they????
Thanks!
SmartAss 12-01-2004, 11:25 PM Umm ok so brown wire tap it to the wire in the black plug on the back of the fuse box..... xa Grey xb Black/White
Is that all you need?
tcm_xB 12-02-2004, 01:57 AM Umm ok so brown wire tap it to the wire in the black plug on the back of the fuse box..... xa Grey xb Black/White
Where is the "back plug" that is located on "the back of the fuse box"? Seriously, I look behind the fuse panel (pic above) and see 50,000 wires in bundles......
SmartAss 12-02-2004, 02:30 AM Just put a fuse on it and run it to the blacl or the black/yellow wire at the ignition harness.
superjeer 12-02-2004, 02:55 AM holy cow, I went out and took a look. That's rough.
personally, I'd jack one of the outs in the front of the fuse bloick that comes on when the key is on the ON position. The cubby says not to use "undesignated locations" though. :)
tcm_xB 12-02-2004, 03:22 AM holy cow, I went out and took a look. That's rough.
I just want to do the install correctly. I'm going to have to find the people with cruise control installed and just PM them and see if they can take a look. This is more complicated than the motor swap I did in my Honda Civic :? BTW > Box is for sale if interested.....
UnFocused 12-02-2004, 06:35 PM Why are you selling?
tcm_xB 12-02-2004, 10:52 PM Why are you selling?
Getting back into the honda racing scene..... Buying a house after the first of the year. Can't have it all :(
tcm_xB 12-13-2004, 01:45 AM Bump!!
