snow and xb
Old Feb 1, 2008 | 08:54 PM
neodemon278's Avatar
Default snow and xb
ok so i did a search and didn't come up with much.
What can i do for my 06.5 xb to make it better in snow. i love my xb and really don't want to get rid of it. most of the problem i have is when its a heavy snow it cant pull its self out.
any suggestions is appreciated
thanks in advance
Old Feb 1, 2008 | 08:58 PM
boostedbox06's Avatar
snow tires ,chains? get some salt and or sand and put it in the tire tracks behind it it usually works for me
Old Feb 1, 2008 | 09:00 PM
thanks boosted i will have to try that out
Old Feb 1, 2008 | 09:05 PM
SciRunner's Avatar
Turn off traction control (TRAC button) when trying to pull out of the snow. It's been awhile but I think that's what the manual said. Purchase better all season tires instead of OEM if you dont want snow tires.
Old Feb 1, 2008 | 09:10 PM
thanks scirunner, i will try that one as well, indiana has the craziest weather, one day its snowing next its sunny and warm weather.
Old Feb 1, 2008 | 09:12 PM
tCscotty's Avatar
Snow tires do wonders. I pass 4WD's all day long with easy. I also up sized my tires to gain a bit of ground clearance.
Old Feb 1, 2008 | 09:14 PM
thanks tcscotty, i thank all of u guys, your all a big help
Old Feb 1, 2008 | 09:15 PM
BilboardxB's Avatar
yea snow is bad in Illinois too, we got alot last night. i just turn traction off and it works fine, just takes a little time i had snow up to where my door opens so its a little annoying.
Old Feb 1, 2008 | 09:28 PM
i got the slush and ice in my wheel wells talk about annoying lol i know how the snow gets up to the door its annoying as well
Old Feb 1, 2008 | 11:10 PM
stew32's Avatar
I've heard people recommend using silicone spray in the wheel wells to help prevent slush from sticking.
Old Feb 1, 2008 | 11:11 PM
i will have to try that as well, thanks for the tip
Old Feb 1, 2008 | 11:27 PM
IH8ONYU's Avatar
+1 --- turn of the traction controll in snow, sand, mud... any time you are not getting traction and trying to pull out of somewhere, this helps...
toyota should have left it off by default, and at least that way you could turn it ON when you needed to controll your traction in loose snow, sand, mud, gravel... it doens't make sence having to turn traction controll OFF when you need to get more traction!
Old Feb 2, 2008 | 03:31 AM
_xB_'s Avatar
Default good to know...
hello, all. nice to know i wasn't the only one thinking and going through this. the box was happy inside the garage but once out in the alley. she was a no-go. had to shovel her out, pull her back in. ended up working from home, today. will have to try the traction off trick. thanks, all.
btw - neodemon278, don't feel too bad. chicago's got that same vibe with the weather.
take care!
Old Feb 2, 2008 | 03:54 AM
BurxBox's Avatar
We have gotten any where between a foot and a half to 3 foot snow drifts here in eastern WA. Mine has been pretty bad in the snow, but I am running the stock tires. I need snow tires in a bad way. The prob is that they are kinda spendy because of the 15" rim. each snow tire cost as much as each of my 20" 30series tires.
Snow tires and trac off will work great. A bag of kitty liter in the back for just in case your tires spin and cant move is always a good idea.
The snow/ice broke my lower lip and skid plate from just pulling backward out of my driveway. crap
Old Feb 2, 2008 | 04:55 AM
bigskyscion's Avatar
I live in Montana where the roads are regularly covered in snow and ice and have been loving the xB, even on long ski trips to Idaho, Utah, etc.
The biggest suggestion I could give you is to install a set of 4 Bridgestone Blizzaks. You can get them at tirerack.com. I got them delivered (2 day Fedex) for approx. $450 mounted, balanced and aired-up. [I did a little looking and you can get a 14" wheel and tire package for approx. $350 plus delivery, although it looks like supplies are low.]
I've had no problem getting around in snow, ice, slush and all the rest with these tires installed. As was mentioned above...I've passed 4-wheel drives of all sizes and shapes with no trouble at all. There is a great tech section on tirerack.com if you have any winter tire questions.
The traction control suggestion works as well, especially if the snow is deeper or slushier and you need a little wheel spin to get things moving.
Hope this helps.
Old Feb 2, 2008 | 05:40 AM
bB2NER's Avatar
Music City Scions
I've never had problems with deep snow. The stock Goodyears and stock springs were all it needed to get me through 8+ inches with no problems. The dashboard was making all kinds of flashing lights and sounds but that was all. I also love the stability thing when it started getting sideways when I didn't want it to.
Old Feb 2, 2008 | 06:41 AM
burstaneurysm's Avatar
We got 9" last night... my car was plowing today, but handled beautifully. Turn off Trac control... it works nicely.
Old Feb 2, 2008 | 06:51 AM
_xB_'s Avatar
Default ?
are you sportin' the stock wheels? my box came with 18" wheels and a bit of a lowered suspension. i'm sure this doesn't help my case much. having a hard time locating a set of stock wheels, locally.
Old Feb 2, 2008 | 07:07 AM
rallying_the_scion's Avatar
TOCC
I live in Alaska, slap a set of studded tires on it and away you go!! one of my xBs has studded tires, the other is regular all weather tires.
Old Feb 2, 2008 | 07:12 AM
bB2NER's Avatar
Music City Scions
Default Re: ?
18"ers and snow do not mix. Did you buy it new with 18"ers. If so you should have gotten your steelies back for use during the winter. Also check with some Scion dealers. They may have some take offs that someone didn't want and you can pick them up really cheap.
