Matrix/Celica 6speed tranny in xa/xb?
Old Feb 2, 2008 | 05:14 PM
xa007xa's Avatar
Default Matrix/Celica 6speed tranny in xa/xb?
Has anyone tried this swap. Does it mate up or are mods needed?
Old Feb 2, 2008 | 05:25 PM
swartzautoman's Avatar
would be nice to know
Old Feb 2, 2008 | 06:50 PM
DriverXa's Avatar
From what I understand the tranny will bolt up to the stock engine. You will however need to notch the chassis to get the tranny to fit, as well as have new axleshafts made. But it is possible to do.
Old Feb 3, 2008 | 07:57 AM
Sasnuke's Avatar
As a general rule with Toyota engines/trannys, the engine block will accept any tranny from that engine series. For example, a 3E engine will accept a 4E or 5E tranny (and vice versa), a 1ZZ will accept a 2ZZ tranny (and vice versa). In the first example the engine series is "E", in the second it is "ZZ". Now if someone tried to bolt it up & it fit, it may have been just luck.
Old Feb 4, 2008 | 10:47 AM
bB384's Avatar
IV ACE
Celica GTS motors (2ZZ-GE) use C160 series transmissions. xA's, xB's and Echo's use C150 series transmissions. You can even gut out a C160 trans and stuff the internals into a C150 series trans. housing. Look up Wraith on this forum he's done it. I'm just too lazy to search for his thread right now. And you do have to notch about 1 1/2 inches out of your drivers side frame rail to do this swap, but its well worth it.
Old Feb 4, 2008 | 02:44 PM
BATComm1's Avatar
I'd like to see a write up on this...I'm really interested !!
Old Feb 4, 2008 | 05:31 PM
greybox's Avatar
This is probably the biggest thing that would make me consider another car over my xB so if it could be done relatively easily it would make a world of difference.
Old Feb 5, 2008 | 02:41 AM
bB384's Avatar
IV ACE
https://www.scionlife.com/forums/vie...802&highlight=
If you want more info do a search for the author named "Wraith". Read all his transmission posts. He knows what he's talking about, I know him personally and I've seen his car with the 1NZ-FE, Levin trans, and supercharger and it hauls ___!
Old Feb 7, 2008 | 04:18 AM
OC_ScionBox's Avatar
i dont think swapping that six-speed will make much of a difference on the xb
Old Feb 7, 2008 | 12:51 PM
sure it would, you wouldn't have to do 4k on the tach when doing 80 on the interstate to begin with,a nd that would lead to better MPG on road trips.
you would also have a higher top end, i my self don't know why anyone would want to go faster. ive had mine to 115 and that was plenty fast enough for me.
Old Feb 7, 2008 | 03:41 PM
jct's Avatar
jct
you can get the same results if you swapped out with a echo tranny all your doing is changing the final drive ratio
Old Feb 7, 2008 | 04:59 PM
do you have the gear specks for the echo trany
Old Feb 8, 2008 | 12:15 AM
greybox's Avatar
Actually it's not the same as changing to an Echo tranny because we (xB owners) don't want to loose the gears we have and the great spacings-we just want a reasonable highway gear on top (that would be the 6th one).
Old Feb 8, 2008 | 02:33 AM
im with you on that
Old Feb 8, 2008 | 02:55 AM
EasysBox's Avatar
problem with notching the frame is you are altering the crumple zone.... i have thought long and hard about this swap, but i think i would be better off just swapping our 4.3 gears with a yaris' 3.7... or there is the trd 4.0, but i have only been able to find the price in yen...
Old Feb 8, 2008 | 03:24 AM
jct's Avatar
jct
just make sure the bolt pattern on the final drive gear is the same
Old Feb 8, 2008 | 03:31 AM
TorchedPerfection86's Avatar
Lehigh Valley Scions
I think id rather spend the money on turboin my xB or superchargin it b4 i buy a tranny with an extra gear....but thats just me
Although it would be really cool to see in person and drive if some one has it.
Old Feb 8, 2008 | 12:49 PM
turbo is a different issue.
what im interested in is lowering my RMPs at highway speeds
Old Feb 8, 2008 | 04:58 PM
EasysBox's Avatar
my research shows that the final drive for the yaris is swappable, it uses the same c50 transmission, the difference is the final drive, that will definitely drop your cruising rpm. i think you can pick up the output shaft and gear for around $450 new from dealer. if you are uncertain about the swap, just go to the dealer and test drive a yaris...
Old Feb 8, 2008 | 06:00 PM
cool
