Scion xB 2nd-Gen Forced Induction Turbo and supercharger applications...
2nd gen xB ECU programming
Old Feb 4, 2008 | 03:38 AM
bb_ist's Avatar
Default 2nd gen xB ECU programming
Does anyone know if the ecu wiring for the 2nd gen xb is the same for the tc? if so.. isn't it possible to use the greddy e-manage from the Greddy tc turbo kit?
Old Feb 4, 2008 | 07:41 PM
lastlookcustoms's Avatar
No, the wiring is not the same. The harness is different. We installed an emanage in the turbo 08 xB that we did here. All by hand.. Cutting and soldering...
Old Feb 5, 2008 | 09:31 PM
bb_ist's Avatar
did you happen to have a diagram for the ecu?
Old Feb 6, 2008 | 02:04 PM
I have all the pinouts and locations written somewhere. I know I sent them to someone on the board here, maybe they will see this post and help you out. I will try to find the paperwork.
Old Feb 11, 2008 | 08:20 PM
XD40tC's Avatar
If someone could send them to me as well thatd be great!
Old Feb 12, 2008 | 12:01 PM
I found these in one of my previous posts. Im not sure where we put the paperwork in the shop with the full breakdown, but this should be most of what you need...
ecu power lead - Black wire terminal A28
RPM Signal - White terminal B122
Throttle Signal - Light Green terminal B115
2 ECU Grounds - White/Black stripe terminals B44 & B46
Airflow input - Violet terminal B118
Terminal A is the smaller connector and Terminal B is the larger connector
Terminals are numbered left to right, top to bottom as if you were holding the connector and looking at the end that plugs into the ECU
12thhawksfan
Jul 14, 2015 06:18 AM
oblivionlord
Apr 12, 2015 12:21 AM
posiden
Mar 22, 2015 03:03 AM
jchuma
Feb 11, 2015 12:55 AM
Kiwibox
Dec 15, 2014 09:46 PM
