Gas Gauge & Low Fuel Light Question
Old Feb 5, 2008 | 12:48 AM
deadtoaster2's Avatar
Default Gas Gauge & Low Fuel Light Question
So I can get about ~200 miles on the first half of a tank, but then I can only get about ~100 miles from half a tank to low fuel light. Does anybody have any idea why this could be? Does the car suck down more gas when there is less in the tank or is the gauge just really off?
Also does anybody know aprox. how far you can go once the low gas light comes on?
One last thing: my low gas light comes on at about 1/8th a tank. Should it really come on this early?
Thanks
Old Feb 5, 2008 | 12:50 AM
RodC's Avatar
Fuel tank = not a cube.
Old Feb 5, 2008 | 12:53 AM
Guess I never really thought about it like that... That does make sense.
Any idea of how far you can go once the light comes on?
Old Feb 5, 2008 | 12:54 AM
RodC's Avatar
Most I've done is about 20 miles after the light came on. I wouldn't want to push it further than that (no pun intended).
Old Feb 5, 2008 | 12:56 AM
draxcaliber's Avatar
yeah, the fuel tank is not one symmetrical shape. the same thing happens to me.
as for when the fuel light comes on, mine usually some on as it closes in on the lowest mark of the fuel gauge. but there are lots of things that change this. how fast i'm going, how much load (gas consumption) on the engine, and i notice that when i start going up and down the long hills of frostburg, my gauge starts reading lower than when it is on level ground.
but usually when i fill up when the gas light comes on, i end up putting in about 12.5 gallons or slightly more in the tank. the tank holds 14.5 gallons, but at that point the fuel pump is probably starting to work very hard.
Old Feb 5, 2008 | 01:02 AM
scgon's Avatar
why is there a R instead of an E ?
Old Feb 5, 2008 | 01:04 AM
R stands for Reserve I believe.
As in... reserve your gas and get to a gas station.
Old Feb 5, 2008 | 01:06 AM
scgon's Avatar
lol that makes no sense y didnt they just put E
anyway, you have a 14.5 gallon tank, nearest i can figure, the low fuel light comes on somewhere around 12.2 and 12.5 gallons consumed. so you could drive around 20-70 miles (depending on conditions and driving habits), BUT your fuel pump will start working really hard to keep gas going to the engine, and if you take a turn too hard, all the gas will slosh to one side of the tank and you'll sputter out for a second because the engine will be temporarily fuel starved.
Old Feb 5, 2008 | 01:07 AM
RodC's Avatar
Because E means "you're screwed" and R means "time to get gas".
Old Feb 5, 2008 | 01:08 AM
i believe the "R" stands for "Refill" just my guess.
Old Feb 5, 2008 | 01:09 AM
RodC's Avatar
^ Reserve
Old Feb 5, 2008 | 01:10 AM
So you could probably go close to another 50 miles if you were driving conservativly. Good to know, thanks.
Old Feb 5, 2008 | 01:13 AM
i believe what i choose to believe, you say reserve, i say refill, because when it gets to R, what do you do? refill it.
but atleast you don't have that stupid italian gas gauges from that lamborgotti fasterossa on simpsons that read "maximia!", "notsobadda", and "abandonossa" or something like that.
Old Feb 5, 2008 | 01:26 AM
RodC's Avatar
It's written in the manual.
Old Feb 5, 2008 | 01:27 AM
dos_techie's Avatar
I thought R stood for "Retarded" As in " Hey Retard! You are about to run out of gas." J/K
Old Feb 5, 2008 | 01:35 AM
lord be praised! somebody who read the owner's manual! anyway, i still like to say refill.
kinda like "E" stands for "Ehhh, there still some left."
Old Feb 5, 2008 | 02:20 AM
CSUnited14's Avatar
one thing i did notice but could be because of the fuel pump or what not... well when im driving the needle is at half a tank. I get home still at half get out let it sit roughly over night and in the morning the gas needle is lower then it was when i turned it off why is this??
Im guessing gas is hot takes up more volume dunno... or the fuel pump empties? dunno
Old Feb 5, 2008 | 03:02 AM
BuddhasTC's Avatar
damnit, somebody beat me to it!
Old Feb 5, 2008 | 03:06 AM
WAlterEgo's Avatar
what a fun fact! im gonna look that up tomorrow i try not to go more than 20 miles when the light is on
