WILL TREADSTONE TURBO KIT WORK WITH MY SUPERCHARGED REFLASH
Old Feb 9, 2008 | 11:39 AM
Rydrdg's Avatar
Default WILL TREADSTONE TURBO KIT WORK WITH MY SUPERCHARGED REFLASH
hey, anybody here try puttin on treadstone kit with trd reflashed ecu ? Right now I hav supercharger on and may be I might go turbo, I was wondering if it will effect my car. Do I need to get it reflashed bak to normal or it is safe to put on?
Old Feb 9, 2008 | 11:42 AM
Ace83's Avatar
Ronin Scion
just put it back to normal and run a fuel management.. just do it right.. but yeah it wouldnt work well
Old Feb 9, 2008 | 11:49 AM
Rydrdg's Avatar
alright, thanks!
Old Feb 9, 2008 | 02:13 PM
shadow12one's Avatar
You're most likely going to be running different levels of boost so it really wouldnt be running all to well.
Old Feb 9, 2008 | 04:19 PM
Joe_Dezod's Avatar
If you use just the TRD flash for engine management and a turbo it wont work well. If you know what the TRD reflash entails, then you can pull timing and adjust fuel accordingly with the piggy back unit you would have from the kit you bought.
Old Feb 9, 2008 | 04:30 PM
Rydrdg's Avatar
so only the dealer can reflashe it bak to normal right, but if i get a turbo kit that come with emanage and a pre map loaded already that should overwrite the existing reflashed rite.
Old Feb 9, 2008 | 04:46 PM
Ace83's Avatar
Ronin Scion
No i dont think it will overwrite.. the piggyback is a different system, the reflashed ecu has a different tune than stock, if paired with the piggyback it will not work well with the altered ecu. I wonder how much toyota charge to retune back the ecu. If it cost a lot then you might be better of getting a used ecu
Old Feb 9, 2008 | 04:56 PM
Joe_Dezod's Avatar
Ace is correct.
The piggy back ECUs only alter signals going in and out of the original factory ECU. Because you have a reflashed ECU, the adjustments will be different than what most people on here have, so any existing tune will not work on yours. I'd say you're better off going back to stock so things can be easier in the long run.
Brammi
Nov 13, 2016 03:46 AM
cessblood
Sep 15, 2015 06:50 AM
Monkeywrench
Aug 11, 2004 02:55 PM
DjFrOsT
Nov 12, 2003 04:51 PM
tstalion79
Nov 7, 2003 10:11 PM
