ABS intermittent
Old Feb 12, 2008 | 05:09 PM
typhoonorchid's Avatar
Default ABS intermittent
Has anybody had their ABS sometimes work, sometimes not?
Sunday it was below zero here and I hit a patch of ice and went sailing, I didn't feel the rumble of the ABS kick on. Today also when I was first driving in a cold car it seemed to not kick on again on ice. Later after the car had warmed up it seemed to work.
Anybody else have ABS not work when really cold out?
O.T. My power garage door seemed to crap out on my during same very cold Sunday. It's still not working. Is it dead or will it function after it gets warmer. It's never done this before. It seems to have power just does not budge the chain, the door is not stuck, can move it by hand.
Old Feb 12, 2008 | 05:21 PM
MadMike550's Avatar
your in milwaukee?
it's been just as cold here in Kenosha...we havent had any problems with ours..although we warm it up pretty well before we go...
ours doesnt enjoy garage parking either
Old Feb 12, 2008 | 05:25 PM
Driver_Lost's Avatar
It was likely working, you just didn't feel it as much because the tires weren't gripping on the ice.
Scary stuff that ice.
Old Feb 12, 2008 | 05:43 PM
MadMike550's Avatar
is you garage door opener plugged in? are the batterys fresh in the remote? does it make any noises when you push the bottons?
Old Feb 12, 2008 | 06:27 PM
Yeah it has power and does make a little noise when the switch is pressed, like it's trying to function, so I don't know....
Old Feb 12, 2008 | 06:42 PM
MadMike550's Avatar
might be burned out..try to disconnect the door from the opener all systems allow you to manually open the roor..open yours manually..
then try and hit your remote or door mounted garage door switch
if I were a betting man.,.I'd say you will need a new one
Old Feb 12, 2008 | 07:41 PM
daneisthegreatest's Avatar
haha also make sure the garage door handle is not turned to the locked position, that would cause it not to open properly
Old Feb 19, 2008 | 08:57 AM
sa_yon's Avatar
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
07tcscion
Oct 8, 2015 05:42 PM
kmouse64
Sep 4, 2015 01:11 PM
Forced4
Aug 25, 2015 08:18 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
