dezon s1 install
Old Feb 15, 2008 | 01:01 PM
JDsciontc's Avatar
Default dezon s1 install
ok guys i have to s1 sitting in my closet for almost 2 months now. im thinking about installing it myself. but with a friend that has some skills with mechanical work. he worked on alot of supercharged stangs along wit help from the mechanics from my scion dealership. i know its a bolt on kit but is there anything the i should look out for while installing it? and how do i tap the oil pan?
im kicking myself in the butt because i have a 06 tc with 62xxx miles on it already. . im not so much worried about the motor because my mechanics said they got me if anything happens to it.
all help will be greatly appriciated.
Old Feb 15, 2008 | 04:33 PM
anurok's Avatar
I would have at least 1 other person with you that has some experience doing it especially if you have never seen it done before.
It will also take a good amount of time to install this kit...looking at an 8 hour day if everything goes perfectly. Try looking for some DIY on the oil pan taps and read into them very carefully.
I would also contact dezod if you need help, they will answer anything for you.
Old Feb 15, 2008 | 05:11 PM
Astoria's Avatar
i usually like to do stuff myself, but i think ill definitely be ordering a pretapped pan
Old Feb 15, 2008 | 07:00 PM
paul_dezod's Avatar
Scionetics
KAD
Install is not bad if you have the tools, some technical know how and a friend to help
Old Feb 16, 2008 | 05:25 AM
JDsciontc's Avatar
yeah my mechanics will come help me if i need it. but im preety confident with my boy. and yeah im deff considering ordering a pre tapped oil pan.
Old Feb 16, 2008 | 05:59 AM
etsnet's Avatar
Get the pre tap pan if you can or if you can do without your car or know a place that can tap it in an hour or so then just pull it and take someplace to get tapped. Also get a wide band and bring your spipe some place to get the bung welded on.
I was in the same boat you were. I really never did too much to a car but plugs, oil changes, and an altanator before I got turbo'd. I was scared for anyone to help that wasn't a turbo installer. I took it to what is probably known to be the best shop close to me (Titan Motorsports). They charged me $2K to install and tune. I got it back and found out they never tuned it and said the base map was fine. I got a refund for the tune but still cost me $1800. Now they charge a lot because of who they are but the install had no problems.
I regret that to this day. I'm now about o drop my new engine in and will be doing the turbo myself and a friend or two (only to make it go faster). It's pretty simple but make sure you get a PnP harness (I think it comes with one). Also make sure you hook the gauges up. I can't see anything being a problem to install it. Go for it and learn and spend the $1K+ for install on some other mod. Good luck.
Old Feb 16, 2008 | 10:00 PM
JDsciontc's Avatar
where can i buy an already taped oil pan from?
Old Feb 16, 2008 | 10:33 PM
etsnet's Avatar
Here's a tapped one...
https://www.scionlife.com/forums/vie...hlight=oil+pan
Old Feb 17, 2008 | 10:08 PM
Scoobasteve4132's Avatar
For about $100, you can actually order the one they use in the TRD Supercharger kit...
Old Feb 25, 2008 | 01:23 PM
JDsciontc's Avatar
Would it be smart for me to order a vaccum block along with everything else? and also what is the purpose of it. can i run gauges off of it?
Old Feb 25, 2008 | 02:20 PM
Ace83's Avatar
Ronin Scion
yup vacuum block is useful get it and its inexpensive.. it help your engine bay organize and look cleaner
Old Feb 25, 2008 | 02:41 PM
JDsciontc's Avatar
yeah im looking at purchaseing the tt vaccum block. will it work with my kit? and what exactly can i run off of it?
Old Feb 25, 2008 | 02:44 PM
Ace83's Avatar
Ronin Scion
sure it will work it.. wastegate, boost gauge, pressure sensor hmm what else
Old Feb 26, 2008 | 12:06 AM
JDsciontc's Avatar
what exactly can i run of the vaccum block?
Old Feb 26, 2008 | 12:34 AM
recliner15's Avatar
anything you want
anything that requires a vacuum source, pressure source
wastegate, blow off valve, greddy pressure sensor, boost gauge, boost controller, black box.. etc etc
Old Feb 26, 2008 | 12:48 PM
JDsciontc's Avatar
ok. thank you guys for all the information. also. whats the best afr gauge? i know aem is one of them but the price is also pretty steap. is there anything else out there?
Old Feb 26, 2008 | 01:54 PM
aen's Avatar
aen
you honestly don't even need the knowhow, it's bassically the easiest thing inthe world, as soon as you start taking off parts your head goes OHHHH, that's where that goes.
Old Feb 26, 2008 | 02:11 PM
Ace83's Avatar
Ronin Scion
^^ lol.. but there's a rule with that.. just dont mess up, lol
