*Disclaimer: any modifications, errors, or mishaps are the responsibility of the User.
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0099.jpg
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0098.jpg
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0100.jpg
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0106.jpg
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0102.jpg
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0104.jpg
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_105.jpg
I am Posting this Article because there was a misperception by a few who are suggesting that the whole Front Bumper
needs to be removed to Access the OEM Foglights. That is Not the Case,
I checked and did not see anyone Post pics on this Subject.
I hope this Helps.
MR LUV
Metro273
02-17-2008, 05:23 AM
Great DIY! Now people can stop asking how to remove the foglights to change the bulbs... :clap:
burstaneurysm
02-18-2008, 05:30 AM
I actually cringed at the use of a prybar. I'd almost rather remove the bumper...
Also, the bulbs can be swapped without removal Passenger access is a pain, but driver's side is cake.
MR_LUV
02-18-2008, 08:38 AM
http://i274.photobucket.com/albums/jj274/LUV_MOBILE/Tech%20Articles/IMG_0108.jpg
You do not Have to use a pry bar. You can use anything you want to pop the foglights.
Even a kitchen utensil like a nylon spatula, a couple of credit cards, your fingernails.
Fishing line use to loop behind the fogs. By showing how it is done, you decide the tool.
With my pry bar, I can pop the foglight in 1/2 second.
Now if you Prefer to Remove the entire bumper...
The Choice is Yours...
MR LUV
Think Out of the Box
dpope
02-18-2008, 06:41 PM
Too risky... I did my HID install on the fog lights by removing the bumper which I found out was so easy... But I agree with burstaneurysm that if it's just a bulb replacement, you can just reach for it... Just have someone with skinny arms to help you with the passsenger side lights...
hawaiiguy
02-20-2008, 12:00 AM
^^^ 'someone with skinny arms to help with the passenger side lights', from where does one enter? from above, or below the bumper???
Metro273
02-20-2008, 12:47 AM
Since I have a lift at work, I put the Box in the air and I can access the foglights from underneath...pretty easy to get to!
Bluelilweet013
01-21-2009, 11:34 PM
I hope this Helps.
MR LUV
Hey Monsieur Luv great DIY post, but the problem that I am coming across is removing the bottom plug, I've tried needle nose plyers, and my fingers but no deuce. I tried just hammering the light in with the plug in but only the top goes in. Any tips on how to remove them?
The Secret is there are 2 locking tabs on the plug behind the bracket.
I used a small pair of ignition pliers (looks like midget Channel-locks) to squeeze the
tabs. In a pinch try a small pocket screwdriver or stubby screwdriver.
You push in on one of the tabs, then rotate it around to get the other tab.
Once you get the plug off, when through, you mount it on the male post of the foglight
like the pic above.
Put a little grease on it, then carefully pound the whole unit in.
Use a rag to protect the lens.
Good Luck.
MR LUV
David_Crawford
05-24-2011, 04:59 PM
Gents,
NEWBIE here. I just bought some Smoked Lense fog lights off E-Bay and they didnt come with the little plugs that snap over the posts on the back of the housings and the local Toyota dealer says he CANT get them. WHERE CAN I GET THEM ??? PLEASE HELP!!
