Fuel management
Old Feb 19, 2008 | 04:31 PM
Zsanz's Avatar
Default Fuel management
has anyone done a fuel management set up or a hot spark ignition ?? anything of the sort?
www.jscspeed.com has alot of parts for out 2ndgens
Old Feb 21, 2008 | 11:07 PM
Zsanz's Avatar
allright...nobody
Old Feb 22, 2008 | 01:26 AM
DJ_FroZone's Avatar
say what?? whats it do?
Old Feb 22, 2008 | 06:04 AM
Zsanz's Avatar
Well the fuel management is going to trick the ECU into allowing more fuel into ur engine at the right time ultamitley creating more horsepower and better throttel response.
The hot spark will hook up to ur ignition making sure that at the higher rpms your spark plug will deliver the same size and power spark as when it was at the lower rpms also reating more horsepower
Just two simple ways to gain alittle horsepower without dropping a T0N of cash
Old Feb 22, 2008 | 02:05 PM
DJ_FroZone's Avatar
how much? cause it sounds like i would do that before a k&n filter change. i take it though that u take a hit in mpg though
Old Feb 22, 2008 | 02:19 PM
jct's Avatar
jct
sounds like a gimmick just spend the money and go turbo
Old Feb 22, 2008 | 02:38 PM
DJ_FroZone's Avatar
r u sure???? i mean a turbo???? ____ why not just install the jet engine. and add NOS!!!
Old Feb 22, 2008 | 03:24 PM
SiZzOuRcE's Avatar
Fuel Managment systems allow you to alter facotry fuel maps throughout the RPM ranges. It requires you to know what your doing when it comes to tuning a car and you will also need a wideband 02 sensor to see what your A/F is at all times. Adding more fuel to your motor doesn't add more horsepower, it just adds more fuel. The trick to tuning a car properly is to adjust the A/F and lean out the motor as much as possible without frying it. When boosting a car, you will obviously need to add more fuel because you are forcing more air. So in turn, if you want to boost your car, you are going to need a standalone ecu or fuel amangment system.
NOS also requires added fuel depending if you are using a dry shot or wet.
On a near stock motor (intake, exhaust) fuel managment is the biggest waste of money. IMO.
Old Feb 22, 2008 | 03:33 PM
DJ_FroZone's Avatar
ya thats what i thought. other wise my cheap butt woulda heard of this a while ago
Old Feb 22, 2008 | 05:05 PM
Zsanz's Avatar
ahhhhhhhhhh i need more power!!!
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
MeDizzy
Oct 8, 2015 03:31 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
paisatronix
Sep 5, 2015 04:13 AM
