chrischoi
02-20-2008, 06:26 PM
When you installed the head unit. Did you ever spliced anything with the brake line so it would play movies while driving?
I thought it was just a pin removed from the harness... The little connector things?
My ebrake light just started turning on when I accel hard. Anything?
O5_TRD_tC
02-20-2008, 06:37 PM
yeah the mute wire the u switched the pin that wire has to be grounded.
FLINTstone
02-20-2008, 07:22 PM
here's the guide i used when i bypassed my D3.
http://www.avic411.com/forum/viewtopic.php?t=7998
all4degame
02-20-2008, 07:47 PM
just take the mute wire and the brake wire and splice it to the huge grounding wire U that is on the harness. Then move the mute wire up a hole. That is what I did, You'll be good to go.
chrischoi
02-20-2008, 10:18 PM
it's already installed.... grrr.... oh well.
so the ebrake line never got spliced...? and there is just a ground running to the one pin in the harness? that's it right?
danoiboi
02-20-2008, 10:25 PM
uh if you are saying you spliced into your actual ebrake wire........yea thats a no go.
very simple. 1) move mute wire 2) ground mute wire 3) ground ebrake wire FROM HARNESS. (not comin out of your car)
so in other words, all the splicing/modifying is done through the two harnesses that come with the d3 unit and plug into its back.
