Stupid Question Please help!!!
Old Feb 20, 2008 | 11:24 PM
streetracergirl's Avatar
Default Stupid Question Please help!!!
What is the pc valve and is it easy to change.
Old Feb 21, 2008 | 02:38 AM
stew32's Avatar
Positive Crankcase Ventilation (PCV) valve? Should be easy. Does it NEED to be changed?
Old Feb 21, 2008 | 03:30 AM
Kanchi's Avatar
It recomemnds being changed @ 30K but you might check it first before just going out and replacing it. BTW it is located here:
https://www.scionlife.com/tech/manua.../tc05_1349.gif
Old Feb 21, 2008 | 05:23 AM
BurxBox's Avatar
Kanchi
Your good you. You. Your good.
Old Feb 21, 2008 | 05:50 AM
SquallLHeart's Avatar
huh? why does it need to be changed?
Old Feb 21, 2008 | 10:29 PM
pinoyFMtC's Avatar
If it gets plugged with dirt or sludge...If its plugged "blow by" gases can't escape the crankcase...
Old Feb 22, 2008 | 01:09 PM
HeathenBrewing's Avatar
PCV stands for Positive Crankcase Ventilation. Essentially it prevents too much pressure from building up in the crankcase. Pressure will cause oil to be forced past the rings. So a gummed up PCV will increase oil consumption.
Old Feb 22, 2008 | 04:05 PM
Default thanks
Thanks everybody for all your help.
Scionxa180
Mar 13, 2015 04:39 AM
r0by
Nov 22, 2014 07:09 PM
xBassist
9
Jan 21, 2004 07:34 PM
TylorWeaver
23
Dec 9, 2003 04:59 AM
tbblizzard
11
Dec 5, 2003 12:21 AM
