Help with some 8"s
Old Feb 24, 2008 | 03:12 AM
sho0b0x's Avatar
Default Help with some 8"s
Which would be better for mid bass?
Kicker 08CVT84
8" 400W 4-Ohm Shallow-Mount Subwoofer
Technical Specification
Sensitivity: 84.8 dB
RMS Power Range : 200 Watts
Peak Power Handling: 400 Watts
Impedance: 4 Ohm
Low Frequency response: 30 Hz
High Frequency Response: 35000 Hz
Diameter: 8 Inch
Features
8" Shallow-Mount CompVT Subwoofer
Peak Power Handling: 400 watts
RMS Power Handling: 200 watts
IMPP woofer cone material
Santoprene surround
Suitable for marine use
Sprialead technology
Steel basket allows sub to keep cool
Priced per speaker
Subwoofers are usually come as a single speaker unless noted differently.
or
Kicker 04SSMB8
8" 350W 4-ohm Subwoofers
Sensitivity: 89 dB
RMS Power Range : 40-175 Watts
Peak Power Handling: 350 Watts
Impedance: 4 Ohm
High Frequency Response: 500 Hz
Diameter: 8 Inch
Features
Tri-Tech cone (sandwiched foam, polypropylene, and woven carbon fiber)
Santoprene rubber surround
low profile stamped steel basket
spring-loaded nickel-plated terminals accept heavy-gauge speaker wire
free-air capability
flush-mount depth 2-5/16"
Priced per pair
Old Feb 26, 2008 | 01:52 AM
Sciond's Avatar
well here is my $.02..the bottom one is more efficient/less power compression....plays in the range that works for mid bass....l
Old Feb 28, 2008 | 09:56 PM
tCeeJay's Avatar
the CVT is made to be a subwoofer. The 04SSMB8 was designed for mid-bass. Pretty obvious choice.
