View Full Version : foglight question
fliggah
01-09-2004, 02:27 AM
I'm trying to see if I'd be able to put other type of foglights so I'd like to know how do you take the temporary plastic filler out....
Tamago
02-03-2005, 01:42 PM
xA? xB? if it's the xA, just grab onto the plastic cover with pliars and pull!
Cockpit_XB
02-04-2005, 04:47 PM
For the XB you might have to lift the car up & pop it out from behind im thinking, if not try using a falthead screw driver to pop that sucker out.
ILLER__
02-04-2005, 04:54 PM
just get on the floor and push out them from behind the bumper...
Fridion
02-04-2005, 05:21 PM
Yes there are two tabs, one on each side. Push them towards the center slightly and there you go...
peterbilt
02-04-2005, 06:17 PM
yep. what he said.
i just added aftermarket fogs to the lower valance this week. got the Lowes OEM switch, split lex tubing for the wires, rectangular fogs to match the headlights... bing bang boom the asian girlfriend looks even better now.
ProjectD
02-07-2005, 05:48 AM
^^^^^ how did you wire it exactly, I have fogs that I want to put in my car but I have no idea on how to wire it up.
peterbilt
02-07-2005, 01:22 PM
the kit i bought came w/ wiring. so i went w/ it. punched thru the big rubber gromet on the firewall at the drivers side (there's a big bundle of wires that go thru there). ran the wires behind the dash and up thru one of the knock outs. flex tubed everything - i mean everything - right down to the lights.
it really was easy. if you don't have a wire kit, it's just a hot, neutral and a ground. i think the wiring was 14G - perhaps 12G, about 10 feet of it.
hope that helps.
8BALL
02-07-2005, 02:12 PM
Wally-World has fog light wiring kits. It comes with a relay, switch and all of the wire you need.
Joehnn
02-07-2005, 02:30 PM
You dont have to lift up the xB and you don't have to use a screw driver. lay on the ground reach behind and undo tabs. Takes less than a minute. :lalala:
