Battery Size
Old 02-26-2008, 07:06 AM
buickid's Avatar
Default Battery Size
Planning some serious audio mods which will require some heavy-duty electrical. What size is the underhood battery, and what group is it? Thanks!
buickid is offline
Old 02-26-2008, 08:44 AM
loneeagle's Avatar
optima are the best batteries in the market but also the more expensive ones , the reason it's because the battery is completly sealed and instead of liquid acid uses acid in gel state which is virtualy imposible to have a leak and also instead of groups of lead plates it uses something like a lead sheets rolled this gives your battery more life time and its maintenance free but if you want sometin' cheaper but good quality, interstate 3478DT (green case ) would do the job
loneeagle is offline
Old 02-26-2008, 01:50 PM
bigpapa's Avatar
You will notice more of an improvement by upgrading your alternator first.
bigpapa is offline
Old 02-27-2008, 12:39 AM
buickid's Avatar
Heh, don't worry, I'm pretty knowledgeable about car electronics. I plan on going with some Deka Intimidators, group 31, if they will fit. The alternator will come in as well.
buickid is offline
Old 02-27-2008, 12:47 AM
Utah Scions
xseveredveganx's Avatar
A group31 will take a little modification... The Deka Intimidators are a pretty decent battery for the money, too. I'd recommend a cold air intake like the TRD to free up some room. When you get the TRD, you completely remove the intake box. That frees up room behind the battery. You could probably do a smaller Kinetik in that area if you wanted to. Just fab up a quick battery box out of some 16gauge steel sheet, drill holes, mount box, done. It wouldn't take too long if you're handy with a sheetmetal brake and a welder.
Aaaaaand I'm in the midst of upgrading my stock alternator. The tC alt does in fact fit. BUT, you'll need to either pull the stock alternator pulley off your xB, but it has a clutch in it... Kinda weird... But www.nonstoptuning.com has a smaller pulley that will work perfectly!
Let me know what you come up with!
xseveredveganx is offline
rain7905643
03-14-2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
02-28-2015 04:20 AM
paolodoctolero
02-22-2015 06:35 AM
blh72
01-31-2015 03:41 PM
Quick Reply: Battery Size
