Shifting questions
Old Feb 28, 2008 | 05:53 PM
B_Izzle's Avatar
Default Shifting questions
My tC is the first manual I've driven, so please forgive the n00bness....
a few questions:
When down shifting, the shifter is very stiff unless I've slowed down to <1500 RPM. Then, its buttery smooth to downshift. Is that normal? Is that like a way to prevent people from downshifting too soon and potentially redlining? (and yes if I downshift before coming down to 1500 RPM or less, I do revmatch. in fact I revmatch regardless)
so will a new short shifter w/ upgraded bushings & bearings make the shifter feel crisp & stiff no matter what RPM you downshift at?
oh, and has anyone ever mis-coordinated their shift, where you release the clutch before you put the shifter all the way into gear? and then you get that awful noise from the shifter stick? once in a while, that happens to me when I shift into 3rd. Will a short shifter improve that?
Old Feb 28, 2008 | 08:24 PM
nominal_asu's Avatar
Short shifter will make the distance you move the handle to shift shorter and make the shifter feel tighter, that is all, It wont stop you from mis-shifting. Everyone does it sometimes, just take your time and you'll do it less as you get better.
I dont know about the downshifting part, I've never had it feel stiff as I go to downshift, I would think it shouldnt though, I dont really look at my tach often, so I have no idea what rpm I'm downshifting at, I just feel it out.
Old Feb 28, 2008 | 08:30 PM
tCeeder's Avatar
Default Re: Shifting questions
that's just user error, you'll do that with or without a short shifter. i do it when im not paying attention
Aroddalobster's Avatar
for me, it's only stiff when i try to downshift into first, like when i come to a stop sign, and i try to put it into 1st so that i cud quickly get back up to speed. the short throw will reduce the amount of shifting you need to do, make the shift a lot crisper and a more sure feeling, and will reduce a lot of the play the stock shifter has when it's in gear.
Old Feb 28, 2008 | 08:40 PM
talagang_crazy's Avatar
short shifter + bushings makes shifting much crisper and tighter. highley recomended, i couldnt see driving my car without it anymore.
as for downshifting, you should pretty much always rev match. 1. it makes your downshifting so much smoother. 2. it puts less stress on your tranny and most likley in the end, keep it running in better condition for longer
Old Feb 28, 2008 | 09:36 PM
CuRiOuSfIsH's Avatar
the only gear that should give "problems" is 1st, above a certain speed, it will be locked out and the gear cant be selected. For the most part, downshifting to 1st in the tC seems a bit unnecessary.
Old Feb 28, 2008 | 10:06 PM
Dont downshift into 1st, its a bad idea and doesnt help much at all, and if i'm rolling slow and need to go again I use second, cuz cars dont like to start in first when you're rolling.
Old Feb 28, 2008 | 10:45 PM
tCeeder's Avatar
i try to use 2nd as much as possible when in a parking lot or whatnot. as for downshifting, brake pads are cheaper (and easier) to replace, so i just use engine braking and the brakes when needed.
Old Feb 28, 2008 | 11:02 PM
hmm yeah, i dont think down shifting into first would be such a great idea. puts alot of strain and in the long run damage your tranny
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
