Anzo tail lights problem...
Old Feb 29, 2008 | 04:45 PM
bsptcftw's Avatar
Default Anzo tail lights problem...
I just installed some Anzo tails yesterday and the problem I'm having is that the parking lights don't work. The brakes and signals work fine. All I did to install them was connect the electrodes and stick the ballast(?) on the inside frame of the car.
Old Feb 29, 2008 | 10:18 PM
bsptcftw's Avatar
i played around with it some more and figured out that the ballasts or whatever they are control the speed of the individual blinkers but don't seem to affect anything else. i tried switching around the plugs some more but only managed to change which half of the light blinks for the blinkers...
the fuses look fine but is there anything in particular i should be looking for that would indicate they are messed up?
Old Feb 29, 2008 | 10:40 PM
ilovemytC's Avatar
either a fuse is blown, plugs are not hooked up right, or the lights are defective. Try disconnecting your battery, switch a plug, and reconnecting your battery. If that doesn't work, disconnect battery again, and try switching the other way. Good luck and if you solve it please post what happened.
Check these two threads out, some other people had problems with the Anzo install:
https://www.scionlife.com/forums/viewtopic.php?t=212982
and this one:
https://www.scionlife.com/forums/vie...oblem&&start=0
Old Mar 1, 2008 | 03:07 AM
bsptcftw's Avatar
Do you need a socket wrench to disconnect the battery or is there an easier way? Positive or negative side?
Old Mar 1, 2008 | 04:45 AM
bsptcftw's Avatar
I unhooked the battery and played around with the connections...no luck, same problem
i think im gonna have to return these or (hopefully) get an exchange...
Old Mar 2, 2008 | 09:06 AM
bsptcftw's Avatar
Anyone know what color the wire is in the fuse box for the parking lights?
Old Mar 2, 2008 | 08:51 PM
bsptcftw's Avatar
Excuse my newbieness but i finally fixed it. Turns out the fuse was blown. But I learned alot with my first electrical mod. Thanks for the help ilovemytc
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
bktply
Scion tC 2G Aero & Exterior
Mar 16, 2015 06:15 PM
TheTripleC
Jan 4, 2015 06:46 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
