Coolant smell on the XB2
Old Mar 2, 2008 | 07:29 AM
motorcade's Avatar
Default Coolant smell on the XB2
Does anyone have a coolant smell on there new XB? But found not leaks.
Old Mar 2, 2008 | 10:03 AM
ibnboxin's Avatar
moto you just pick up your xb less then about 2000 miles ago. if so i had that type of smell. but went away. even went so far as to park it in the garage or place cloth under the car to see if it was leaking. it is some type of coating they put on the engine. there is a post in this forum about it or the power and drive train.
Old Mar 2, 2008 | 03:31 PM
kbrady2's Avatar
i still have the smell at 6700 miles and they say its ok.. i don't think it should still be there though.
Old Mar 2, 2008 | 11:18 PM
wrczx3's Avatar
You are smelling coolant from the vent on the coolant overflow tank.
Old Mar 3, 2008 | 02:14 PM
tanker's Avatar
I have it also and I have 9800 on mine. Just had it in but they a=say all is OK and I have found no leak.
Run it till it drops.
Old Mar 3, 2008 | 02:43 PM
postman's Avatar
Default smell
8,000 same thing here...................
Old Mar 3, 2008 | 04:00 PM
wrczx3's Avatar
If you had a leak, you would have to add coolant!
Old Mar 3, 2008 | 06:04 PM
xhrhx15x's Avatar
8100 miles on my xB2 and i still smell it. i had the dealer pressure check the system and all is fine.
Old Mar 5, 2008 | 01:11 AM
dmanotas's Avatar
12K on mine and still smell it....No leaks have been found!
Old Mar 6, 2008 | 03:11 AM
motorcade's Avatar
My car has 9980 miles on it and the dealer had the factory come down and check i out. the tested the car for 6hrs and found nothing. the smell even comes inside. the factory said the car checked out 100% and the smell is normal. how thay think this is right i dont know. if i would have known this i would have kept my 06 xb and never wasted a dime on this car. so i might try and lemon law the car and get all my money back and find a older xb
Old Mar 6, 2008 | 03:12 AM
motorcade's Avatar
oh if anyone wants to buy my xb i would consider selling it.
Old Mar 6, 2008 | 03:19 AM
xseveredveganx's Avatar
Utah Scions
I'll trade you straight up for mine. It doesn't have the smell...
Old Mar 6, 2008 | 05:28 AM
08xB714's Avatar
i thought mine smelled like clutch burning....
so it's a smell of coolent?
Old Mar 6, 2008 | 02:40 PM
xhrhx15x's Avatar
A smell is not enough of an issue to do a lemon law on it. Especially since we all are saying the same thing and the dealer never finds anything wrong on any of ours.
Check Here for your states Lemon Law.
Old Mar 7, 2008 | 06:35 AM
motorcade's Avatar
smelling coolant cant be good for you, and if someone passes out from the smell while driving then what? I don't know about you guys but i didn't pay good money for a car to smell like that. .
Old Mar 15, 2008 | 01:56 PM
underESTIMATED's Avatar
OhioScions
I remember having it at 24,000 miles on my 1st xB2.
2nd xB2 no smells yet. But I'm only 551 miles so far.
Old May 8, 2008 | 09:18 AM
zio's Avatar
zio
Default coolant smell? I think so too
Coolant smell could be hot rubber and plastics, when no leak is found and you know something that smells a lot like coolant is leaking or very hot but no leak is found, right?
If your radiator is leaking a very small amount of coolant up high on the finned surface then it would evaporate before pooling, it might be behind the shroud.
Or the engine bay could be too hot- as mine seemed to be. before I got my Zio MOD.
I made a MOD to help with this SMELL- I call it the ZIO MOD.
Zio
Old May 13, 2008 | 03:07 AM
Adamzxb's Avatar
I smell it too.
Old May 13, 2008 | 04:34 AM
PlowWalkxB's Avatar
So Zio how much does your MOD cost and is that MOD on a '08 or '09 2nd Gen xB?
I had an '05 xB and LOVED it until this guy in a Ford F-350 decided to turn into me and T-boned my bueatiful xB so I;m in the market for an '09 xB and when I get my settlement with his insurance I plan on purchasing an '09 xB but I've been looking at the posts and searching the internet for any and all things that are wrong with the 2nd Gne xB. When I asked my dealership and the ervice department about this issue of extremely hot engine compartments all they said was that they have not seen anything about this issue and that they get updates as problems are sent out from the manufacturers.
I just don't want to be purchasing a LEMON if there is a problem witht he 2nd Gen xB I would just rather look long and hard for a 1st Gen xB (they seem to get better gas milage even though they don't have the same power as the 2nd Gen xB)!!!
Old May 13, 2008 | 04:44 AM
MaxBoost925's Avatar
You guys don't read. That coolant smell is a chemical that the Toyota factory coats the engine (metal pieces) in order to prevent rust. After about 5000 or so miles, that chemical fades away naturally. It creates a coolant-like smell when heated.
You can clean it away manually (I did so with some armorall and a microfiber towel.)
My $.02
