NEED HELP ASAP. Pictures Provided.
Old Mar 2, 2008 | 07:33 PM
BadNewsSS's Avatar
Default NEED HELP ASAP. Pictures Provided.
I just got my 16x8 rota pdcs. they are +35 offset. I was test fitting the back wheel and it has very little clearance like maybe a mm away from the beam. Will the 10mm OTG shim take care of this/ Does anyone run these without the shim. If they do, how??
Old Mar 2, 2008 | 07:35 PM
silverstreaktc's Avatar
Buy wheel spacers.
Old Mar 2, 2008 | 08:23 PM
BadNewsSS's Avatar
I had planned on putting on the OTG 10mm shims, and -3 camber shims, so I'm guessing now would be a good time to do that. I was going to wait until I got coilovers..
Old Mar 2, 2008 | 08:27 PM
IowaSciontist's Avatar
I wouldn't run camber on a +35. Your tires will most likely rub your shocks. The spacer s will improve what you have now, but to run camber I'd suggest 20mm spacers. OTG has minimum offset requirements listed on their site.
Old Mar 2, 2008 | 09:06 PM
BadNewsSS's Avatar
This is from their site..... help me translate. It says.... 8.0"
36mm or more you will need to run the camber.shim combo?? I will be running a 205/50/16 Falker 512.... Thanks for the help.
Old Mar 2, 2008 | 10:16 PM
According to that, you will be safe by 1mm. But keep in mind, all tires are a little different. Better to be safe than sorry. Also, if your wheels aren't out far enough before camber, you will be way sunken in after. A +17 F and +10 R sit flush without camber on a 8" wide rim, so to avoid unsightly overlap with camber, it's nice to be past that. I would say with your offset, a 10mm spacer, and -3 camber, you are probably going to have 1.5" or better overlap. Meaning gap between fender and tire. So I would try a 20 or 25 mm spacer. IMHO.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
prescottn
Oct 8, 2015 05:31 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Andreas24
Sep 15, 2015 02:10 PM
prescottn
Sep 13, 2015 09:04 PM
