Time for the TRD supercharger
Old Mar 2, 2008 | 10:04 PM
Blacklistcustomz's Avatar
Default Time for the TRD supercharger
Alright to start off, im not sure if any post is out there that answers these questions. I searched but i could not find anything, so here i go.
I'm planning to buy the supercharger, from trdsparks.com. now i read up on the turbo thread on the parts and all that, however i dont think i need all that stuff for the supercharger. I was wondering if someone could help me setup what i need and sorts for the s/c.
I want to make a list of prices and sort, and here is what i have so far:
1. TRD supercharger: $1900, trdspark.com
2. Clutchmasters lightweight flywheel: $370, killertc.com
3. Any recommendations on a clutch?
As of right now, i have an injen intake, and trd axle back exhaust. Im not sure if i need a full exhaust? Do i need a different intake? Do i even need a new clutch? Do i need a new ecu?
Any help would be great!
Finally, i have been seeing some dynos of the trd s/c. Scion rates this thing at getting up to 200hp. Now, i have seen dynos that have around 230hp, even one (icenine's) that had 311whp w/ the trd supercharger. How are they getting that kind of power out of a supercharger? I would love to get around 240hp.
Engifineer, if you see this post then im sure you can answer everythin
Anyways someone help me set this up and teach me a little about how to get 240hp with the trd s/c.
Old Mar 2, 2008 | 10:07 PM
Oh and one more question... I saw a video that had a trd s/c w/ a BOV... i didnt think you could do that but i guess you can... anyone want to explain how i set that up?
Old Mar 2, 2008 | 10:37 PM
Rydrdg's Avatar
Default Re: Time for the TRD supercharger
nst 9.5 psi pulley and greddy ultimate emanage plus watermeth and a tune will bring u close to 240 and 250 hp.
Old Mar 2, 2008 | 10:40 PM
2_much_tc's Avatar
you wont be able to use your CAI with the S/C...
You can get a full exhaust if you wanted (header, s-pipe, cat back)
for a clutch, go Stage 3 (as recommended to me by Dezod)
And like rydrdg said, 9.5lb pulley, water/meth, and some type of engine managment will do good...
Old Mar 3, 2008 | 12:05 AM
tc4joe's Avatar
any recommendations for us auto guys? you guys think its necessary to do the transmission upgrade service that places like www.levelten.com perform?
Old Mar 3, 2008 | 12:15 AM
MkhoiD's Avatar
automatic TRD supercharge on the Tc on put out 189whp, w/ 9psi pulley...O_O....any ideas that could bring it to 200+ whp ? 189whp that's with full exhausts 9psi pulley CAI and a greddy emanage...could it be the place that did the tuning?
Old Mar 3, 2008 | 12:39 AM
IcetC's Avatar
personally from what I hear about the emanage stay away the tcs hate em....unless u go with the ultimate were u can control more things than the blue I personally am going with an aem f/ic with the dezod pNp harness with trd exhaust k&n cold air dc header and 9.5 pulley looking to get around 250-260 whp hopefully yea u don't need a clutch right away but eventually it wouldn't hurt...I take my car to the track so I'm going to upgrade clutch plus also so I can put slicks on my car gl btw
Old Mar 3, 2008 | 12:46 AM
Alright so this should be my list?
1. TRD supercharger
2. 9.5lb pulley
3. water/meth?
4. engine management
5. a new clutch and flywheel
What exactly is water/meth?
And how do i put a BOV into the system?
Old Mar 3, 2008 | 12:53 AM
2_much_tc's Avatar
Good luck with that. You won't even get close to that with those mods you mentioned...
Old Mar 3, 2008 | 12:54 AM
2_much_tc's Avatar
Here is some info for the water/methanol injection...
http://www.snowperformance.net/
Old Mar 3, 2008 | 01:02 AM
Ukno0003's Avatar
1: you can use a cold air intake with a supercharger, you either have to buy an intake that will work with the s/c or you have to change your intake you have to work with the sc.
2: You cant use a BOV with the supercharger, he was probably running a different BPV they work in 2 different ways.
3: How to get to 240+ whp - CAI, Header, s pipe, full catless exhaust( ptuning or dezod turbo exhaust because of the s/c you loose the need for the backpressure. so you dont need to worry about losing some low end trq to get hp) 9.5 lb s/c pulley or possibly the 12 lb s/c if u want more boost. some kind of engine management and a good tune. Watermeth is a possiblity to. You can also get a crank pulley, lsd, new clutch/ flywheel. If you even want more power then that, build your engine. You will need gauges - boost, oil temp, and a/f ratio id sugeggest.
4: if im leavin out somethin some one jump in.
Old Mar 3, 2008 | 01:08 AM
fu<k i still have no idea what i want to do yet.... i really want the greddy turbo, however, the trd s/c is a ____ ton cheaper... thanks for the help so far, but i have more thinkin to do... greddy = expensive when you add in the emanage and a clutch....
Old Mar 3, 2008 | 01:17 AM
Ukno0003's Avatar
the supercharger build can get pretty pricey to if you want to get up to 240+. Dont forget to add in installation if you arnt installin it yourself
Old Mar 3, 2008 | 01:44 AM
1_kLEan_tC's Avatar
Wow...that all your put out...I thought the 9psi pulley would put you to 200whp...I guess not! that sucks...
Old Mar 3, 2008 | 02:36 AM
MkhoiD's Avatar
yep, cause stock...automatic puts out 130whp. i believe.
IcetC's Avatar
yea thats why i said hopefully for my whp goal but eventually i will go full exhaust and stuff...back to blacklist if you want the bov sound i would suggest getting what i just picked up a forge splt-r bpv still offers the sound the only thing is you won't be able to hold full boost with it if you are looking to keep max boost i would upgrade to the forge 007 bpv but you don't get the sound
as for the water/meth can someone chime in because i am kinda interested in that as well. thanks
Old Mar 3, 2008 | 02:45 AM
I had no idea that so much went into the trd s/c.
What happens when you buy it from scion? do they give you the clutch and a new pulley?
Old Mar 3, 2008 | 02:56 AM
1_kLEan_tC's Avatar
No...they dont....You dont NEED the new clutch or pulley....that only if your going to up boost...
Old Mar 3, 2008 | 03:06 AM
05-RS1's Avatar
no, tranny upgrades wont be necessary for the s/c + conventional mods. a tranny cooler wouldnt hurt though, but like i said, not necessary.
i made 212whp 180tq @8.4 psi. i was using the nst 9.5psi pulley tuned with greddy eman. ult. so could be your tuner..
Old Mar 3, 2008 | 03:13 AM
What would i expect to see on the dyno with only the supercharger?
Can i put the pulley in later when i get more money?
