Upgraded rims and got lots of Warning lights....HELP...
Old Mar 3, 2008 | 07:10 PM
didja's Avatar
Seven City Scions
Default Upgraded rims and got lots of Warning lights....HELP...
A guy changed his rims on an 05 xB from the stock 15s to 16's with 205/45/16 tires and now all of a sudden it is giving him all sorts of warning lights.....traction control, stability and check engine lights.
Was wanting to see if anyone had ever ran into this problem or knew of anyone. Looking to see if it's an easy fix. Dealership wants $100 just to answer the question. Does anyone know if the tire/rim sizes can be programmed into the computer to adjust the system for the change?
Old Mar 3, 2008 | 07:12 PM
chopmondo's Avatar
are they balanced?
Old Mar 3, 2008 | 07:19 PM
rickbreitenfeldt's Avatar
Your Low tire Pressue System is very unhappy with you. You need to swap the stems off of the stockers or go to a dealership and buy another set and then have the dealer reset the system. The $100 better be applicable towards the stems and reset or go find a different dealer.
Old Mar 3, 2008 | 07:37 PM
Capt_pooty's Avatar
StyleWagons
ok here is what has happened...
I had bags and this is what happened to me you have rubbed through your abs sensor wiring.. with the tire and you have the abs,traction, and there is a third light can not remember now...
That was my experience and sounds the same with your buddy... good luck that pig tail is about 165.00 plus tax unless its under warranty then its free baby I said FREE!!!!!!
Old Mar 3, 2008 | 08:02 PM
burstaneurysm's Avatar
There is no tire pressure monitoring on the 1st gen xB.
Old Mar 4, 2008 | 12:45 AM
CamoTrav's Avatar
I was just about to say that.
Old Mar 4, 2008 | 02:37 AM
swartzautoman's Avatar
haha yeah
Old Mar 5, 2008 | 06:26 AM
chadly's Avatar
same thing happened to me when i put on my 501's i just took it to the dealer and they had to reset the sensors then everything was fine.
Old Mar 5, 2008 | 08:28 AM
magicmanjk808's Avatar
most likely a disconnected abs sensor....
or, if the wheels have been on for a while, like someone previously mentioned, you probably rubbed through an abs sensor wire.
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
killahXB2
Mar 27, 2015 10:45 AM
herwig
Scion tC 1G ICE & Interior
Mar 23, 2015 04:19 AM
TheTripleC
Jan 4, 2015 06:46 PM
