? for those that installed a head unit in the xB storage bin
Old Nov 18, 2004 | 07:32 AM
SuperCrunchyAction's Avatar
Default ? for those that installed a head unit in the xB storage bin
I installed my new clarion deck in the storage bin under the stock head unit location. I got the idea from this forum and it's a great idea. It was a little more involved than I figured and the only issue I have is that the radio hits the air duct which is right behind the storage bin location. Not a big deal but I will probably grind down the coin holder on the fold down door for more clearance so I can close it with the faceplate installed.
Anyway, my question is, how did you guys secure the headunit in that location? Right now I have just a pressure fit and it's secure but can still be moved about with little effort. I need to secure it for insurance reasons so i'm looking for some ideas.
Old Nov 18, 2004 | 09:39 AM
Big_hungry's Avatar
good question. i was wondering the same thing. Hopefully someone comes up with a few ideas.
Old Nov 18, 2004 | 11:40 AM
rcstprez's Avatar
I used the metal install sleeve that comes with the head unit. I marked where 4 of those bending flaps were on the cubby hole, and then used a drill bit to make a hole in the cubby. Then you can bend the flaps in the sleeve up, which then locks the head unit in place.
Old Nov 18, 2004 | 05:30 PM
Good idea, I thought about doing this but was pressed for time the day I installed it. Is there any risk of damaging the soft vent behind the storage bin? My clarion does press against it slightly.
Old Nov 18, 2004 | 05:32 PM
TOAST3R's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=27518
Old Nov 19, 2004 | 07:21 AM
Cool, thanks... A tip for anyone that's going to do this. A dremel with a small drill bit will make short work of the plastic you need to remove that's part of the dash behind the small bin. Use it like a rotozip.
Old Nov 20, 2004 | 03:25 AM
junklr's Avatar
Like this? Use back straps, and no need to grind anything!
Old Nov 20, 2004 | 07:50 AM
Looks good. I had to grind down the coin holder or whatever that protrusion is on the pocket door. My Clarion deck is probably longer than your Alpine. How did you get power to your monitor?
Old Nov 20, 2004 | 11:46 AM
rcstprez's Avatar
I got power for the monitor from the stereo harness. You have a constant 12v and a switched 12v right there to run a relay off of. Prolly dont even need a relay, but I just wanted to put one in there.
Old Nov 20, 2004 | 04:05 PM
Are you concerned about voltage spikes due to the unregulated power? What kind of relay.. specs or whatever, it might be somehing I'd like to do too.
Old Nov 20, 2004 | 06:05 PM
rcstprez's Avatar
No, not really concerned. No reason really, I have just always used relays when hooking up multiple items to one power source..just habbit I guess.
Old Nov 20, 2004 | 11:53 PM
-Keith-'s Avatar
Since I cut the back housing off tapped it to the rest of it with some electrical and took the housing sleeve and bent the tabs up so it catches good
Old Aug 20, 2005 | 02:52 AM
TheSpillmonkey's Avatar
ok people, i f*cked up. I destroyed my storage bin faceplate trying to cut a hole in it to have my head unit poke out of the storage bin. what do i do.... i guess i can put it there for now w/o the faceplate to do the install, but ill need to think of something.
Old Aug 20, 2005 | 03:11 AM
BEASTXB's Avatar
my pioneer unit fit nice and snugg, doesn't move at all you can try to drill some hole on the side
Old Aug 20, 2005 | 07:45 AM
oBnoXious_XB's Avatar
my head unit got stolen from the storage bin today, along with my lcd monitor. but yeah it is a good place to have it.
Old Aug 20, 2005 | 07:57 AM
aireck's Avatar
ouch.. sorry to hear that.
did they do damage to your ride besides that??
Old Aug 20, 2005 | 08:26 AM
just a scratch on my drivers door. I only had my setup for 7 days
wiltonhall
Jun 23, 2025 10:09 PM
clickclickw00t
Feb 18, 2015 08:57 PM
NewBox06
Feb 3, 2015 04:02 AM
billzor
Scion tC 2G ICE & Interior
Jan 17, 2015 12:38 PM
lunchbx05
Dec 11, 2014 06:13 PM
