Lazy steering and Hard to brake???
hi
I have an manual 06 xb with 15k miles and latelty its gotten more difficult to turn the steering wheel
and to stop I have to press on the brakes harder than before. Is this a hydraulic problem and if so how do I check or fix??
Dealers here suck so I want to avoid that route
it is called "you are a weak little b!tch and need to hit the gym" syndrome.
but on a serious note, i have no idea. it would have to be something to do with the power steering, so start there.
yeah ... that's what i fear. i guess i have to take it into jiffy lube for a quick diagnosis huh.
from what i've researched, it could be a whole slew of possible problems from the steering rack to loose bearings or dried grease or leaking fluid or cold fluid or etc ...
Originally Posted by evosky
don't wanna bring this back from the dead, but i am ....
i'm getting the same problem. the steering wheels is like ... crazy hard to turn. what are the possible reasons?
True story:
We did the poly end link bushings on my and a friends car, the next day he asks me if my steering is "hard to turn"
I say... well, no... it just feels a bit tighter I think.
He goes away.
A few minutes later he calls concerned "the damn poly bushes did something to my steering"
I tell him, no, if it's that bad it is an hydraulic problem. He insists ... "it's got to be the damn bushings we thight them too much"
I say, IT'S NOT the frikin bushings! be right there.
I get there, try to move the steering, it's a friking race car, the thing won't move while parked, I open the hood and see the shredded belt spinning around.
See... it was not the bushings
yeah i just looked under my hood, and i see one of the belts slipped off and is shredded. so i prob shouldn't drive the car right? is it safe to do so?
an how quick and expensive of a job (if i take it to a shop) is it to replace the belt? i have to drive home this wednesday, and i dont want fix this before then ...
If you need to drive it, cut the shredded belt completely off, the P/S belt only drive that so you can jsut drive w/o P/S w/o damaging the engine.
It will be harder to turh the wheel so that is a distinct negative.
The belt will be $10-15, and a shop shouldn't charge you more than a 1/2-1hr labor tops for it.
RY_TC07
Jul 18, 2017 05:18 PM
kdanie
10
Jan 25, 2004 07:08 PM
