What the he*l?!
Old Mar 10, 2008 | 04:08 PM
bruceg's Avatar
Default What the he*l?!
I need you guys' help! Yesterday my dad put some anti foulers on my downpipe to try and keep the CEL off. Well, he took it for a ride yesterday and said it was fine...today I went to go to the doctor...and it's running like complete sh*t! As if an intercooler pipe is loose or something...all the vac lines are fine...all the intercooler pipes are fine...I'm lost...running like a charm one day and the next....crap...
Dezod stage 1 kit...10.5PSI..AEM f/ic...700CC injectors...blah blah....anyone think of anything???
Old Mar 10, 2008 | 04:54 PM
kikcaffine's Avatar
Leak somewhere.
Old Mar 10, 2008 | 05:17 PM
Schuller's Avatar
The anti-fouler needs to go on the second O2 sensor on the s-pipe. NOT on the O2 sensor on the downpipe.
Old Mar 10, 2008 | 05:33 PM
paul_dezod's Avatar
Scionetics
KAD
Correct-o-mondo
Old Mar 10, 2008 | 05:43 PM
Mr_Meaty's Avatar
Yes...second 02 sensor...and make sure to disconnect the negative battery terminal for 15min as well.
Old Mar 10, 2008 | 06:48 PM
bruceg's Avatar
I didn't mean down pipe. I meant S pipe. I took the anti foulers off to just see if that was the problem...sure enough it's running like normal...I have no idea how that has sh*t to do with it..but it did.
Old Mar 10, 2008 | 06:54 PM
mriches's Avatar
Sounds like the anti-fouler might be leaking. Try putting copper silicone RTV on the threads before putting it together (both fouler and sensor threads).
Old Mar 10, 2008 | 07:42 PM
Schuller's Avatar
Did you guys drill out one of the antifoulers to 1/2 inch? Should drill out the one that the O2 sensor screws into. Then screw that into the other antifouler. then the whole thing into your s-pipe?
Old Mar 10, 2008 | 07:46 PM
bruceg's Avatar
Yeah, we drilled it and all. I just tok em off. MY tuner just suggested that I try it because with the CEL on it makes my car run rich at idle.
Old Mar 10, 2008 | 11:28 PM
recliner15's Avatar
they wont get rid of ur CEL anyways.. just go back to what you had before the antifoulers
